Sponsored by:
Sponsored by: CARiD
Someone please explain how this works
Old Aug 24, 2003
fuledya's Avatar
Super Member
fuledya is an unknown quantity at this point
I bought the Revo SS and in my hast to install this awesome product I never compared it to the stock shift assembly. I was wondering how it actually reduces the throw by 40% (claimed by manufacturer)? All I do know is this is by far one of the best things I've added to my car, along with Capyoda's bushings.
So exactly how does it work????
Old Aug 24, 2003
Slumpert's Avatar
Slumpert is an unknown quantity at this point
2 ways
First - It is a shorter shaft.
Second - The cable attachment is further up on the shaft
The result is goodness indeed.
Slump
Old Aug 24, 2003
Dr5D's Avatar
ive always wanted a short shifter, but wouldnet it be easier to screw up your gears?
Old Aug 24, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
how do u figure?
Old Aug 24, 2003
fuledya's Avatar
Super Member
Screw up the gears? How do you figure?
All it is really is a lever which pulls on two cables. If the shifter rod is shorter, and the cable mount is higher on the shifter, all it's really doing is using less motion to achive pulling out the same amount on the cable, understand what I mean? It really makes sense if you pull your center console off and look down in there and see how it works. I wish I would have been the one to invent it!
Old Aug 24, 2003
fuledya's Avatar
Super Member
damn double post....
Old Aug 24, 2003
Dr5D's Avatar
yea, I know how it works, but it just seems that to would be more likely to slam into gears or somthing
Old Aug 24, 2003
fuledya's Avatar
Super Member
Slam into gears? Explain please. What's slamming?????
Old Aug 24, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
lol not to be a D1CK .. BUT u have NO idea what ur talking about ... sooo shhhush.
Old Aug 24, 2003
Dr5D's Avatar
its hard/bad for the bushings to put it into a gear quick and hard
Old Aug 24, 2003
Dr5D's Avatar
what are you talking about?
Old Aug 24, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
what does that have to do with a short shifter? if you shift properly it makes no difference how hard u slam into gears... what ur talking about is what happens when people dont know how to shift period.
Old Aug 24, 2003
AzNmiKex215's Avatar
2k1civic.com O. G.
maybe he scared of miss shifting cuz he hasnt used a short shifter before
Old Aug 24, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
thats retarded cause its ten times easier to shift with a short shifter.
Old Aug 24, 2003
01WingsWestCivic's Avatar
7thgen Man-gina
01WingsWestCivic is an unknown quantity at this point
well what are you talking about sir?
what are you talking about idiot?
i dont know what are you talking about stupid?
lol, sorry
Old Aug 24, 2003
Marion26's Avatar
Marion26 is an unknown quantity at this point
Installed the Revo ss myself and was amazed as to the simplicity and yet the effectiveness of the product. All I say is try the product and install it yourself you'll be proud of your work and will be smiling everytime you shift.
Old Aug 25, 2003
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
yep ... I would ALWAYS grind my gears and misshift ... I swear like once a week ... but I don't with my revo
Old Aug 25, 2003
RunawaySoul's Avatar
RunawaySoul is an unknown quantity at this point
In layman's terms, it's just a different way of shifting...a different way of getting from point A to point B... Point A and Point B itself never changed, just the way to get there, no better or worse. That's the only analogy I can think of relevant to the conversation.
Old Aug 25, 2003
Dr5D's Avatar
my 2nd gear bushing went bad with my stock shifter, so thats why I am worried about a shorter one
Old Aug 25, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
dude u just gotta learn how to drive stick better... get the short shifter... it obviously cant make u any worse.. having less distance to travel hopefully can only make u better.
Old Aug 25, 2003
Renamazazo's Avatar
Renamazazo is an unknown quantity at this point
Actually, a short shifter in theory could make your synchro's wear out faster, since the shifter is moving faster, that means that there's more pressure on the gears, BUT this is really only a problem if you're being retardmo and not feeling the transmission. SO if you shift properly, then it shouldn't do any harm, but if you don't then it'll make things worse. You know when you're shifting right when you feel the car slide into gear, and not stick or bind up. To do this, you have to shift at a variable speed. Go really fast till your just about in gear, pause for a split second to let the synchro's mesh properly, then push it the rest of the way in. IT's actually very simialr to how you use a clutch properly...
I hope this helps.
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
werdnahall
May 17, 2015 11:37 AM
ORskier
May 3, 2015 12:54 PM
EC3
Apr 22, 2015 07:55 PM
ImmortalEX
Jan 2, 2002 08:45 AM
