lower grills
The Standard One
lower grills
post pictures of your grill and where you got it.
i bought this aluminum mesh grill in the cement section at home depot and it was just too thin.
looking for something thicker. i have the viper front and it came with grills and i'm looking for something like it but i cant seem to find it anywhere.
That actually brings up something I mentioned on another thread.
How do you know that the mesh someone sells is a good thickness?
Does Home Depot sell a thicker mesh wiring?
I'm curious where people get their mesh grills, too. Especially if it's around the San Diego area.
VNlilMAN- what about the upper grill? Did you put wire mesh there too, or an altezza grill (or stock)? I can't really tell, but I don't see the emblem, so I think you did SOMETHING...But I see the emblem in other pictures (the "before", I assume).
Try here: http://www.grille-tech.com/detail.html?prodid=114
I bought 2 grilles from them. Very good materials, looks great, and STRONG . I bought the black racing style for the civic and RSX. Looks very good.
It's not aluminum, but powdercoated steel. I had to modify the RSX grille slightly because of the foglights. Had to cut 1/4 inch off each side. The steel is so strong I had to use a grinder. The grilles appear to be lasercut, and come wrapped in a high quality molding.
Worth it.
Worth it.
The Standard One
i would say ask for a picture of it. the one i got from home depot was thin, you could basically see everything behind it. it was as if there was no grill.
the upper grill was an altezza grill. i didnt like it so i put the stock one back on...
blah i dont have a stock bumper so those grills wont work(and too expensive =p).
jackoncruzpr
Sep 29, 2015 07:59 PM
