Venom 400 Performance module...
7thgen Power Maker
VENOM 400™ Performance Control Module
The VENOM 400™ Performance Control Module is an add-on control unit that features its own micro-controller. This module is connected to the vehicle's sensors and increase engine performance by monitoring the sensors output characteristics and modifying the input to the existing vehicles computer.
VENOM 400™ Advantages
The VENOM 400™ improves horsepower by as much as 25% through the range of approximately 1,000 to 5,000 RPM. The VENOM 400™ is OBD II compatible. Besides a substantial increase of torque, the VENOM 400™ reduces flat spots or delay time during sudden acceleration.
The VENOM 400™ incorporates an 8-bit micro-controller that is capable of monitoring the various sensor inputs and modifying their output at more than 40 times per second.
If you have already installed a performance prom, the VENOM 400™ will enhance the vehicle's performance beyond the parameters set by the performance prom.
The VENOM 400™ is only active when peak performance is required. During normal driving, the VENOM 400™ remains passive until the microcomputer determines that engine airflow and throttle position warrants increased performance. Normal fuel economy prevails while under normal load.
The VENOM 400™ enhances the performance gains achieved by installing an upgraded chip. Whatever the gains are as specified within the chip, they will be magnified through the use of the VENOM 400™.
The VENOM 400™ has an off switch so smog certification is achieved when not racing.
The VENOM 400™ will not trigger the emission safeguards of today's vehicles.
Easy installation in 20-30 minutes with basic hand tools requiring only four electrical connections.
Red cockpit LED indicating VENOM 400™ activation.
Up to 25% more increase in horsepower throughout the power range of 1,000 to 5,000 RPM (where the vehicles red line is 6,000 RPM).
The flat spot or delay found with automatic transmission downshifts, which can be as much as three seconds, is eliminated (when equipped with auto instead of manual).
ANY ONE GOT ONE? SOUNDS NICE!
Originally posted by ohmysac
i had one on my auto...worked great...so much slower when it was turned off
I've got it... it works great, I noticed it work the most when I had it off all winter and then turned it back on when it got nice. It definitly helped the RPM's move through the gears a little quicker, meaning faster acceleration. I would recommend it it anyone.. I got mine off groubuycenter for like 260 a while back so I would check there for the best price.... and its easy to hook up, the hardest part is running the LED through the firewall! other than that its just 4 wires in the engine bay, positive, negative, TPS, and MAP....
From what i have been reading this Venom 400 Module can be used with the JET ECU...which in all gives even more horsepower and response...if there is a group buy for the Venom 400 Module again, i'm definitely gonna grab me one...den i be one fast auto! Haha....
I can do I DIY for the venom 400. I just got mine today. You all make me leary about it though as far as if it will be good or not. I'll keep everyone up to date. Thanks again navyedoc. Hope this was worth it, huh? laters-
Search and Learn
