2 questions
Old May 23, 2018
Kristoliquid's Avatar
Kristoliquid is an unknown quantity at this point
2 questions
2 questions (2007 civic dx-g)
1. i got myself dialectric grease and was wondering if i had to unplug the battery to grease some connectors, or i just put grease on all the connectors i see.
2. my ac blows hot so im trying to look at the fans to see if they turn and other diagnostics. How long does it take for the fans to start spinning after turning the ac full blast and being idle. I tried it between 5 to 10 mins and nothing happened, or it takes longer than that.
thx.
Old May 24, 2018
Re: 2 questions
WHY?
If the fans and compressor clutch did NOT turn on immediately, the AC system is probably empty.
Old May 25, 2018
Re: 2 questions
I figured since I live in Canada and the car is always outside 4 seasons, that if I put such a grease on my connectors it would make them not corrode or last longer.
Old May 25, 2018
Re: 2 questions
WHat connections are you thinking of? Most of the connector shells are already weather sealed and grease might compromise the sealing ability.
O2 sensors can be ruined by greasing the wiring with silicone.
Plus, the grease attracts and collects DIRT and generally makes a mess LOL
Old May 25, 2018
Re: 2 questions
Ah ok I didn't know that. I figured maybe humidity would pass through. Because it's just plastic.
What would be a good use for it then. Battery terminals and spark plug
Old May 25, 2018
Re: 2 questions
I use silicone grease on brake hardware more than anything LOL
Old May 25, 2018
Re: 2 questions
Isint silicone grease and dialectric grease two different things or its the same.
Yeah I use silicone on those bolts in the caliper if the pads use unevenly.
Old May 25, 2018
Re: 2 questions
The stuff I use at work is dielectric silicone and the tube also calls it tune up grease or something like that, I guess I just refer to it as silicone grease though.
I don't think it's exactly the same as, say, Sil-glide and the like, but I don't have any of that to look at.
Dielectric is an insulator too.
xmeeksx
Jul 27, 2003 09:04 PM
etrnlderek
South Cali
Sep 7, 2002 01:12 PM
GQCiViC
May 1, 2002 10:44 AM
ademarco6
Nov 12, 2001 06:52 PM
redneck2k1
Sep 9, 2001 09:04 PM
