Two general questions
Old Jul 22, 2016
Meanie's Avatar
Meanie is an unknown quantity at this point
Hi, I have two general questions about my 2014 Civic EX coupe I hope can be answered.
First, I am aware I can disconnect the fuse to my daytime running lights and they will still work with the high beam if needed. The problem is, I like my DRL, especially since I installed LEDs, but there will be times I need to turn them off. Therefore, I thought about installing a switch within the fuse somehow, allowing me to turn on or off the DRL at will. Anyone know how to do this?
Second, since installing the LED for my DRL, I like the idea of completing the entire vehicle with LEDs. I had to install a load resisters for the DRL to eliminate the "check DRL system" message. Therefore, if I installed LEDs to the rest of the vehicle, will I receive more messages and require more load resisters? I didn't find anything in the manual about warnings for the DRL, thus, I didn't know it would partake. The same applies with the other lights as I don't know if a warning will display.
Thank you
Old Jul 23, 2016
Re: Two general questions
Wires, switch, fuse holder and fuse, and male spade terminals the proper size so you don't ruin the terminals inside the fuse box. Maybe someone makes a fusebox tap that can plug in to a fuse slot?
No, DRL are the only ones with a warning system.
Turn signals will probably need resistors so they don't blink rapidly, but I haven't done this conversion myself so that's only a guess. Try without and see what happens?
Old Jul 23, 2016
Meanie's Avatar
Thank you, ezone.
On my motorcycle, the signals blink faster and I know this is common with cars when a bulb is burned out, at least that I'm aware of in the past. These newer cars have so much in features I have no idea what they will do.
Old Jul 23, 2016
Had a minute to look in a diagram, I see the turn signals are controlled through the multiplex system (body controller) so you will probably need load resistors on the turn signal lights to make them flash at a reasonable speed.
Old Jul 23, 2016
Meanie's Avatar
If I don't use resistors, does that mean I will receive a message or will they simply flash faster?
BTW, with your parts suggestion for the DRL switch, how would I hook install it all?
Old Jul 23, 2016
The turn signals will probably flash at an extreme rate.
OptimisticWay
Jan 3, 2016 07:54 AM
05Ep3k20si
Electrical
Nov 6, 2015 04:26 PM
pnamajck
Oct 27, 2015 07:09 AM
klam
Nov 16, 2001 03:36 PM
wsking77
Aug 29, 2001 05:34 PM
