Honda civic 2006 coupe..bypass lighter to stay on
Old May 20, 2009
rock88's Avatar
rock88 is an unknown quantity at this point
Hi there ,
I have a 2006 honda civic coupe ..i have 2 power outlets in the car a cigerette lighter and one middle compartment.
it seems these are only able to use when the car is turned on ...
i want to know if these could be bypassed as I want to able to use these when the car is turned off..
I know alot of cars can do this..any ideas would be appreciated.thanks
Old May 20, 2009
Re: Honda civic 2006 coupe..bypass lighter to stay on
well its gonna require some rewiring. mainly running a wire from the + battery (with the proper fuse ofcourse) to the socket's power wire and splice it in. i think the stock wire is only 16 gauge, so you could use that and maybe an 8 or 10 amp fuse.
Old May 21, 2009
CraigW's Avatar
You will also want to isolate the factory connection to prevent the constant voltage from feeding back to other items.
Old Dec 17, 2009
rjmlakota's Avatar
rjmlakota is an unknown quantity at this point
How is this done?
Thanks,
RJ
Old Dec 17, 2009
CraigW's Avatar
^^^^ You will need to cut the wire going to the center lead of the outlet (leave some wire remaining on the outlet so you have something to work with when doing the new source connection) Also fold the cut end of the factory wire over and tape it with electrical tape to isolate from shorting to ground.
You should also fuse near the source connection of the new constant 12volt source with an inline fuse holder.
jessicakaybby
Apr 20, 2015 12:11 PM
