Caliper size on LX the same as DX?
I'd like to go from 16" tires down to 195/65r15's on my 8th gen civic LX for fuel economy reasons and less load when accelerating; and my desired wheel covers for 15" steelies would be an esthetic plus.
would doing this mod, if possible, affect speedometer accuracy? I have read similar posts, but none that definitively answer my specific questions. Thank you!!
Click Here
Received 1,161 Likes
Rep Power: 100 Re: Caliper size on LX the same as DX?
I can't find anything non-Si related that I can rely on, but I don't believe the LX would have different brakes to an EX.
So long as the wheel diameter stays the same, speedo accuracy won't be an issue.
Received 1,460 Likes
Rep Power: 341 Re: Caliper size on LX the same as DX?
speedo accuracy depends on tire OD, not rim size
Super Moderator
Received 1,908 Likes
Rep Power: 198 Re: Caliper size on LX the same as DX?
Looks like tire diameter is the same as the stock 16" wheels. EX and LX calipers and rotors are all the same. I don't know if 15" wheels came stock on any of these or not. As long as it clears the caliper, it should work.
The following users liked this post:
Deniro (4 Weeks Ago)
The Hybrid, GX and DX trim came stock with 15" rim and tires. They're 195/65r15's. My LX came stock with 205/55r16's
Super Moderator
Should work fine then.
turboslug
06-11-2004 03:57 AM
