Another ac related question(s)
Rep Power: 0 Another ac related question(s)
I guess for the 100th time but I'm on my phone and trying to search forum with my phone is kinda bugged or something. Anyways...
Blows hot
Compressor won't turn on and radiator fans won't turn on when I put max ac in the car.
Maybe a relay, gonna take the AC compressor relay off and use one that's upper left of it to test it.
Can I still add freon with a little can even if the compressor doesn't engage and the fans don't start? Or it's just gonna create pressure because it's not flowing or something.
Or any ideas?
Thx
Blows hot
Or any ideas?
Thx
Received 1,129 Likes
Rep Power: 191 Re: Another ac related question(s)
If you don't have a set of gauges, use a small flathead screwdriver to briefly press on the valve stems of the fittings. If nothing comes out you have no pressure.
Rep Power: 0 Re: Another ac related question(s)
"Honda - tried, true & tested...!"
Theres a good chance it Just needs a R134 Freon Top up Reason why i say this is wifes vehicle had no freon in the (condenser -where freon is stored) either it Lost it slowly from use over time. or it has a very very small leak in it. not sure but i got it Topped Up & Dye added. since my mechanic Ran a Vacume check on it useing his A/C machine and said it holds vacume he just topped it up with R134 and it blew cold again. might Just be Your case as well?
hey there brags its been darn near HOT .! "out here in London Ontario Canada" last few days my
A/C works ok but
im kinda leaning toward it needing some fill of R134 freon as described should i take it to honda or what do You 8th geners recommend i do for cold blowing air. ?
Compressor kicks in, or is working. You should be able to spray the product in in my case compressor was not working to draw the freon content from a similer can as shown into the A/C system if Your useing one of these bottles just make certain its got a gauge on it so You can measure the safe amount going in Your A/C system and dont end up overcharging it with to much freon thats prety critical...! lol
Well looks like you need a recharge, if you don't have a proper set of gauges that shows high and low do not attempt to do it yourself. Best to take it to a shop. I bought a set of gauges off amazon for like $80.
Do not put stop leak stuff in there.
Do not do what they're doing in the above video, you can still screw up the AC system since there's only the one gauge
many techs and few people i personaly now have used this similler product with no reprocotions. i beleive as long as Your carefull at adding Just enough freon as shown in the video it should be ok to use. squirt - squirt just enough in at a time and check gauge. But Yes on the other side of the Coin (IF Your plans are to keep Your vehicle for the Loong Haul) then Yes take it to a Licensed A/C Mechanic as mentioned from me Just to be on Safe side.
The stop leak thing is a comment separate from the video.
The stop leak stuff can gum up the very expensive machines the professionals use and can gum up the AC system in your car.
You shouldn't use the single gauge system because you can't see the high side at all and can easily screw it up the AC system. Especially with how picky Honda's are and how little freon they hold.
so i started the car and as soon as I putted some freon in the fans and clutch engaged (filled to the blue pressure gauge which is ok). But it still blows hot and the clutch is activated non stop (maybe its normal, i dunno) also the fans. Maybe it needs more time to go through the system or something?
Those DIY freon with gauge cans are garbage and as been advised should not be used. Also advised is not using a "stop leak" additive. With HVAC sometimes there isn't a cheap route.
May need to consult a local mechanic.
So what could be the solution to fix such an issue. I'm thinking of buying a good AC vacuum and recycler and something that can add freon at the same time. Should I just suck everything out dry and put new in?
Or it's more technical that that?
To be honest my knowledge of HVAC is pretty limited so maybe the mechanics here will chime in. I've used a black light at night around the engine bay to find leaks after dye was injected but for that particular car it was leaking from the evaporator under the dash. Not being able to find a leak anywhere else deduced the leak down to the evaporator. I traded the car in so I never fixed the issue.
Alexrf0
04-02-2018 10:04 PM
Rufus
04-26-2009 11:32 AM
mrb420
01-21-2006 11:34 AM
