replacing torque strut
Old Apr 10, 2018
shrim's Avatar
shrim is an unknown quantity at this point
Hey guys- first time poster here.. it appears I have a damaged torque strut mount (see pics), but notice how the joint on the right seems kinda bent? I was just wondering if that's something that will fix itself when I jack up the engine and attempt to move it back into place while I replace the torque strut mount. Or is a more major repair needed? Also, notice how the engine has come forward, it will be difficult to move it back into place to get the new mount in.. any tips? Thanks in advance.
ID:	112120   Click image for larger version
ID:	112121   Click image for larger version
Old Apr 11, 2018
Re: replacing torque strut
Daaaaaaaaaamn!
That's the lower control arm. Looks normal to me. Compare to the opposite side.
The engine will rock A LOT, it's suspended by only two mounts above.
Just push it wherever you need it to go so you can assemble the new torque strut.
Old Apr 14, 2018
manuelf9837's Avatar
manuelf9837 is an unknown quantity at this point
torque strut in autozone for $70 +/-,support chasis of car with jackstands and then use jack on engine or tranny (protect with wood piece) to install new torque strut. not too hard................Regards.....Manuel
Old Apr 14, 2018
Also if new torque strut does not go in easy then you might have a bent subframe I think that is what you are pointing out in picture
integ108
Aug 6, 2003 06:08 PM
ripper
Jan 9, 2003 01:02 PM
danscreations
Nov 2, 2002 10:03 AM
Boilermaker1
Oct 17, 2002 08:54 AM
ohmysac
Jul 2, 2002 07:29 PM
