Average age of bearings?
Old Mar 21, 2017
Pranav Kharod's Avatar
Pranav Kharod is an unknown quantity at this point
I ve 1.25 k on odometer.
i have been suggested to change the rear right side bearing.
Average life of bearing would be ?
and showroom ppl are asking 14k.
pls suggest.
Old Mar 21, 2017
Re: Average age of bearings?
Some may outlast the car, others may need replaced sooner.
There is no specific life expectancy.
A wheel bearing is good until it goes bad.
A bearing then needs to be replaced when it goes bad.
Old Mar 21, 2017
what are the signs of it going bad ?
what complications I can get into for not replacing them?
Old Mar 21, 2017
Most failures will cause noise.... Most average drivers don't seem to really notice the unusual noise until it becomes very loud and sounds like a small 4 passenger single prop aeroplane flying next to your car.
Ignoring the problem, depending on how bad it gets, can lead to significant damage and considerable expense....and if a bearing problem allows the wheel to become loose, you could lose control of the car, the wheel could detach itself from the car (fall off), causing harm to yourself, passengers, and others on the road.
Old Mar 22, 2017
I surely have some sound from the rear wheel which was not there a while back.
thank you for the reply !!
Old Mar 22, 2017
Tire tread irregular wear can also cause noise that sounds very similar to a bad wheel bearing
Old Mar 22, 2017
Decided To replace them.
Any suggestions what to watch out for ?
Getting it done in a garage and not a show room.
Old Mar 22, 2017
Inferior quality parts
