To full flush trans or not?
I have a 2006 Civic EX Coupe. 196,000 miles on it. Have been doing drain and fill at favorite fluid place about every 30K or so. Just had 3rd gear pressure switch in the AT fail, had it replaced, things appear to be fine so far. I stop at favorite fluid place, ask them to do a full flush (all old out, replace with all new) and they won't. They say they won't guarantee the work, because at that mileage, could "shock" the transmission. (Their words). They recommended a couple of places that would do the work.
So...I know it will start a debate, but, what's the over/under on this one? The fluid is darker and slightly burnt smelling (could be result of switch issue, and I think it would be best to have clean fluid. Doing a drain and replace until it was all replaced will take a while and be expensive compared to just flush it.
Let the battle begin.....
Thanks
Thanks
Re: To full flush trans or not?
That is standard practice on Honda transmission.
At my shop we do a double drain and fill.
-drop fluid
-add
-run 10 min.
-drop fluid again
-add
-shift through all gears while running
-turn off
-check level.
The forced flush machines can cause honda transmissions to fail 9or so I've been told, I've never tested one to find out, lol).
-drop fluid
-add
-run 10 min.
-drop fluid again
-add
-turn off
-check level.
Thanks
Thanks
The other pressure switch may do the same thing at some point too.
Did you remind the favorite fluid place (JizzyLube?) that they have been changing the fluid every 30k up to this point already, it's not like this would be the first ATF service in its life----- and a full 9 or 12 quart service isn't going to do any more harm than a 3 quart service?
If you can change your own oil, you can DIY the trans fluid service.
I'd use Hondas fluid though.
