How to remove/replace engine spash shield fasteners?
Old Jul 27, 2016
ken4444's Avatar
ken4444 is an unknown quantity at this point
I was changing the oil in my 2014 Civic sedan last night and noticed that the plastic engine splash shield (under the engine bay) is held on by a series of plastic rivet things. Several were missing and that might explain the noise I hear when driving.
Can these plastic rivets be removed and re-used? Or are they a one-way part? Can I buy them from the local auto parts store, or should I get them from a Honda parts place? Does anyone have a part number?
Also, there is a metal splash shield directly under the engine that was held on with metal screws. How many screws are supposed to be there? I only had 3. Does anyone have a part number for these?
Thanks!
Old Jul 27, 2016
Re: How to remove/replace engine spash shield fasteners?
Pushpins can be reused many times, at least until they are broken. Most of these on the shields will be 10mm diameter.
You can buy from a dealer, buy online, or likely find somewhat suitable cheap replacements from a parts store or bodyshop supply store.
The Civic splash shields metal chunk should be held by 4 6mm screws and speednuts. After the cross (Phillips) is stripped out of the screws I usually replace them with regular bolts because those are much easier to find in the shop.
Catalog link will have all the Honda part numbers you could want:
http://www.hondapartscheap.com/auto-...der-cover-scat
The upper left area shows the under-engine panels
HTH
Old Jul 27, 2016
ken4444's Avatar
That's good information. Thanks very much. Are the push pins removed by pulling out the center part?
Old Jul 27, 2016
Yes, center pops out first, that allows the 'legs' of the outer part to collapse and come out of the hole.
A couple of small pocket screwdrivers usually works ok.
Check out the first one you remove so you can see how it works.
tomas6791
Jan 21, 2016 02:19 PM
morkys
Oct 29, 2015 06:16 PM
damahark
Oct 28, 2015 08:11 AM
morkys
Oct 25, 2015 09:29 AM
Stussey21
Oct 22, 2015 06:28 PM
