Phantom ABS activation after rear bearing replace
Old Jan 24, 2016
pbft's Avatar
pbft is an unknown quantity at this point
Just replaced a rear wheel bearing on my 2009 Civic EX. Now I get semi-random ABS activity under light braking on dry pavement. No ABS light, and brakes are fine. ABS activity is very light and brief, may happen once or twice, or not at all on any given stop. Doesn't seem to happen under hard braking, though I haven't tried enough to be positive.
Looking at the bearing assembly, I don't see the toothed gear that I'd expect. Not sure what the ABS sensor is supposed to pick up, and no idea what's causing the bogus ABS activation. Any thoughts?
Old Jan 24, 2016
Re: Phantom ABS activation after rear bearing replace
If a shop did it, take it back
Old Jan 24, 2016
pbft's Avatar
If a shop had done it, I would have taken it back in a heartbeat. I need to figure out if I might have done something wrong (hard to imagine what in this case - pretty simple job as far as I can see) or if I need to send the bearing back.
Old Jan 24, 2016
Assuming the ABS sensor is not damaged.....The magnetic encoder ring is probably damaged or weak. Replace bearing/hub assembly -- again (warranty if possible)
I strongly urge you to use a part sourced from a Honda dealer.
KEEP IT AWAY FROM MAGNETS!
The encoder ring is a magnetic strip embedded in one of the bearing seals. It is very susceptible to damage from close proximity to magnets. You can't see the damage by eye but there is a tool that can show the magnetic fields in the ring.
One possibility is the ring is damaged magnetically. The cheezy little magnet in a pocket screwdriver can ruin it.
Another possibility is weak magnetism in the ring...Its pattern could still appear ok when using that tool above, but that can't determine the magnetic field strength.
Seems likely if you used aftermarket part.
Again, I strongly urge you to use a part sourced from a Honda dealer.
Old Jan 24, 2016
pbft's Avatar
Well, that makes sense - wondered if that's how it worked. Part should still be under warranty.
Deeup511
Aug 30, 2015 04:48 AM
honda.lioness
Aug 6, 2015 11:58 AM
denierlexiese
Aug 5, 2015 08:58 PM
Yuendawg
Nov 27, 2001 10:30 AM
civicPesek
Nov 7, 2001 11:33 PM
