Hesitation and roughness past 2500rpm
Old Dec 1, 2015
bklynrx7's Avatar
bklynrx7 is an unknown quantity at this point
Arrow Hesitation and roughness past 2500rpm
Hello everyone, I just recently purchased a 2006 Civic ex and this is my first post. The car has 65k on it and was maintained very well by the PO as far as I can tell. It runs great with just a few exceptions.
First of all the car seems to struggle when trying to rev past 2.5k rpms. There is a very noticeable hesitation accompanied by a vibration that is felt through the car. The boggy feeling and vibration go away once the rpms drop or if I give it more gas. Speed does not make a difference.
Additionally, I haven't been getting good gas mileage. I have been averaging 24mpg which is below what other people are reporting with similar mixed highway/city driving.
I changed the oil and cleaned the MAF so far. Im suspecting it may be an injector issue so I am going to try running a can of BG44k through the tank, then changing the plugs this weekend. Any other ideas or suggestions would be greatly appreciated.
Old Dec 1, 2015
mac25's Avatar
Dr Krieger of Modification
Re: Hesitation and roughness past 2500rpm
Are there no codes? maybe your CEL is burnt out, scan it anyway.
Check all your plugs for spark/condition
If those are good then there most be a timing or fuel delivery issue.
(try renting a fuel pressure test kit).
If you have low fuel pressure the pump may no longer be able to flow efficiently at high demand.
Old Dec 2, 2015
bklynrx7's Avatar
I don't have a CEL, but I will go get it scanned. I have an OBDII scanner that works on every car I have tried, including other hondas, but it doesn't work on this car. Apparently this specific scanner has issues with the Civic and the Fit.
If the bg44k and the new plugs don't do the trick I will test the fuel pressure and take it from there. Thanks.
Old Dec 11, 2015
Scanner needs to be new enough to work on CAN systems.
Old Dec 11, 2015
bklynrx7's Avatar
Arrow Re: Hesitation and roughness past 2500rpm
It was a CAN scanner, and it worked on newer cars than this civic. Unfortunately it's a cheap Autel and it seems to have problems specifically with the civic and fit. Luckily, I had an even cheaper Bluetooth ODBII dongle laying around that doesn't work on my Audis but works perfectly on this civic. I used the Torque app and scanned it finding no issues. I also was able to read my fuel trims, which I was asked for on another forum, though I don't know what to make of this info yet.
As far as the hesitation goes I have an update. While I was waiting on the bg44k and new plugs to come in the mail, I continued to drive it and simply rev into and past the problematic range once a trip or so. The hesitation and roughness gradually diminished and the problem is basically resolved now. I just put the bg44k in and I will see if this clears it up entirely. Im assuming there was just buildup from years of only being driven in traffic and the legendary "italian tune-up" did the trick.
I haven't measured mpg yet, I am going to wait till the BG44k is out of the tank and I get the new plugs in.
Old Dec 11, 2015
once a trip or so.
Does this hesitation issue only happen once per trip?
About the same place each time it happens?
(or roughly the same time from startup, or any clue that makes this a predictable event)
Old Dec 12, 2015
bklynrx7's Avatar
No, the hesitation was happening any time I would try to rev past 2500 rpms under load. It didn't matter if I had been driving 10 minutes or 2 hours. I meant to say that I purposely revved into and past this problem area once a trip or so in an attempt to resolve it.
jferristx
Jul 8, 2015 10:09 PM
Coronet 500
Jul 3, 2015 04:45 PM
hayden55
Jul 2, 2015 06:12 PM
Markias
Detailing
Nov 4, 2001 05:15 PM
