Which Fluids New 1.8L Civic
Old Aug 1, 2014
Timbogates's Avatar
Timbogates is an unknown quantity at this point
Arrow Which Fluids New 1.8L Civic
After many years 15 I purchased a new Civic 1.8L. I am one that likes to take care of that vehicle but since it has been a while things have changed. I have always used the tradition oil brands and changed every 3,500 miles. Now there are blends with synthetic and those that are fully synthetic. I do like the idea of going about 7500 miles as convenience using fully synthetic. I have always heard if you start with fully synthetic stay with it forever. If I start with a blend can I go over to full synthetic without issues? I will also be changing my autotransmission fluid at the regular intervals too.
OK all that said and I do need feedback on oil. What are the other two biggest items I need to do for PM (other than coolant changes, oil, trans) that are very important and non forgiving??
Old Aug 1, 2014
jordan1794's Avatar
jordan1794 is just really nicejordan1794 is just really nicejordan1794 is just really nicejordan1794 is just really nicejordan1794 is just really nice
Re: Which Fluids New 1.8L Civic
What type of money are you willing to spend?
To be honest if I want to put mid-quality oil and filter in my civic it costs more to do it myself than getting the same quality oil change at the dealer...
Now, I can put oil and a filter in it that some MIGHT claim is better than the dealership oil, but it's still gonna cost me around 60$ to do a change, whereas most dealers charge between 30-40.
If you get it changed by a honda dealer just let the car tell you when to change it, read your manual to learn about the maintenance minder.
Tell us more about your car, what year, sedan or coupe, trim level etc.
Also if you don't have the manual let us know, we can tell you how to check the minder, and reset it if you do any changes yourself.
Old Aug 1, 2014
GolNat's Avatar
Prelude Owner
Stick with a high quality oil and you will be good. Honda's blend of oil is a very good blend and you can buy cases online for not to expensive. Oil technology has come a long way, some manufactures like Mobile 1 and Amsoil have a 15K and 25K mile oil. Even conventional non synthetic can go longer then 3500 miles.
There is no harm in switching from conventional to synthetic.
Old Aug 1, 2014
CraigW's Avatar
2011+ should have synthetic from factory IIRC.
The dino oil in my 2010 would likely be at 7500 if I went by MM. If/When getting a model using synthetic have always thought that I may try the 7500. The last 2 Civics have me changed to 5K
ATF every 30k DW-1, Brake fluid 3 years. Honda Genuine.
Old Aug 1, 2014
Timbogates's Avatar
I have a LX with a 1.8 automatic. I have a manual but do you know where I can find a free service manual for I guess anything after 2011?
Old Aug 1, 2014
Free service manual?
Old Aug 3, 2014
Timbogates's Avatar
Do you know of a good link for a service manual? Also what is a good grade of coolant to use in the 1.8L Civic? 2013. What has happened to all the antifreeze coolant (anti rust / water pump lubricants) you can add to the fresh antifreeze on a change?
Old Aug 3, 2014
Service manual, no. Buy a subscription to Honda Service Express?
https://techinfo.honda.com/rjanisis/logon.asp
Original coolant is good for 10 years/100,000 miles, or maint minder item #5. (Check your owners manual)
If you MUST replace it, get the correct coolant (Honda Type 2) from any Honda or Acura dealer.
Why on Earth would you do that?
Use the correct product in the first place.
NO additives.
Page 275 in your sedan owners manual:
Do not add rust inhibitors or other additives to your
vehicle's coolant system. They may not be compatible
with the coolant or with the engine components.
See the same page for more info on coolant.
(Might be around page 255 in a coupe owners manual)
See that entire section for how the maintenance minder works.
HTH
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
Xuhme
21
Aug 7, 2023 03:40 PM
mattdoc
Mar 14, 2017 12:10 PM
bsmiley
Apr 27, 2015 01:27 PM
Richkid23
Apr 19, 2015 12:53 PM
