Timing belt blew, fixed it by car won't fire up.
Old Mar 23, 2014
Iwantatruck's Avatar
Iwantatruck is an unknown quantity at this point
I'm stumped. The Timing tensioner blew up which ripped the timing belt while I was on the highway. I knew there could be engine damage but wanted to try and fix the belt and see what happened. I changed the tensioner, the timing belt, the ignition coil, the distributor cap and rotor. The car still wont start. Fuses are all fine, and once the new belt was on I could turn the crankshaft manually with out any issues. The engine turns over but the car just won't start. What am I missing? I can't figure out whats wrong. Oddly I don't hear the fuel pump when I turn the car to the "on" position but don't see how that could be related. Any ideas would be a big help.
Old Mar 23, 2014
Stock 99's Avatar
Re: Timing belt blew, fixed it by car won't fire up.
^ this
When the belt let go the pistons probably slammed into the valves bending them.
now you need a new engine....or car.....or truck, I guess.
Love your user.....I want a truck as well
Old Mar 23, 2014
mikey1's Avatar
uuummm, yeah,
you probably bent alot of valves which means little or no compression,
without good compression your engine is not going to run, or not well anyway,
time for a new cylinder head
Old Mar 23, 2014
GolNat's Avatar
Prelude Owner
Yep, valves are bent. Or open your current one up and replace the valves.
Was it overdue for a timing belt change?
Old Mar 24, 2014
jamesking91's Avatar
jamesking91 is an unknown quantity at this point
Also make sure that your car is back in time. If you look at the wheel wherre the timing belt is there should be a little arrow or line you need to make sure that they are all the same. Best to piont them all in the up postion than put the belt on. If your car is out of time it will run like crap and or not run at all.
CarStuff
Dec 6, 2020 12:52 PM
mattdoc
Mar 14, 2017 12:10 PM
bsmiley
Apr 27, 2015 01:27 PM
Blaster30
Apr 22, 2015 12:21 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
