2010 Civic brake fluid change question
Scheduled in upcoming pads and brake fluid change (73k ++ on pads
Going to grab Honda fluid to take.... how much fluid do I need to purchase ??
Helper guy said 2 and was going to take 3 but wanted to check.
Thanks !!!
)Going to grab Honda fluid to take.... how much fluid do I need to purchase ??
Thanks !!!
Re: 2010 Civic brake fluid change question
I'd say minimum of 2. One for the lines, one for the reservoir. More if you like to get fluid thoroughly moved around LOL
I use a fluid sucker and straw to empty the reservoir as much as possible first, then fill it (that's most of the first bottle) and use the sucker on each bleeder.
Um, when we did the brake hydraulic related recalls on the vans, they figured bleeding through 4 pedal strokes at each bleeder got any air all the way to each wheel and out.
Thank you sir, will likely grab 3 then. They should have some to add if they need a bit more, hopefully DOT3.
Much appreciated.
Much appreciated.
Xuhme
21
Aug 7, 2023 03:40 PM
mattdoc
Mar 14, 2017 12:10 PM
Linda0818
Apr 23, 2015 11:30 AM
aus10
Apr 13, 2015 09:26 PM
