Strwaberry Milkshake! Help me please...
Honda Newb
Rep Power: 0 Strwaberry Milkshake! Help me please...
2006 LX Coupe Automatic
So my car almost overheated the other day and when I went to check the coolant res. I saw the horrible pink sludge. I then pulled out the ATF dipstick and saw more pink sludge!
I assumed the ATF cooler busted and the coolant and ATF mixed and all hell broke loose, but upon further inspection of the rad. I noticed that there aren't any trans lines running into it.
So... where is it? and what the hell happened to my car
Can someone please help me figure this out, I'm in fear for my wallet.
Rep Power: 787 Re: Strwaberry Milkshake! Help me please...
every honda that i know has a radiator cooler for the auto trans. keep looking, the hoses are there at the very bottom. look for the filter (#7) and follow the hoses.
This is THE FIRST I have heard of this problem happening.
How many miles on the car?
Pic above: Part #1 is the ATF cooler, it is a liquid/liquid heat exchanger bolted to the front of the trans.
That is the only place coolant and ATF can breach a seal and intermix.
That trans is probably ruined. Coolant will delaminate clutch linings from the plates.
Only time will tell, and you should know pretty quick after you get it driving again.
Next problem: Did the engine block crack to cause the initial coolant loss??? This could change everything if it was the cause of the original coolant loss.
Why yes, yes it is. I didn't look.
Another thought: ATF inside the cooling system will ruin all the rubber parts from the inside out. All the hoses, the water pump seals, etc. A miserable job to try to clean it all out.
yeah im hoping that never happens. may as well call it a total loss and junk the car. the amount of money and labor wouldnt be worth replacing every hose and waterpump, plus a new trans and radiator. may be better to cut your losses and try to sell if the car still drives.
Honda Newb
Rep Power: 0 Re: Strwaberry Milkshake! Help me please...
My brother bought the car salvaged has 70500 miles
That most likely had a lot to do with this happening, so we're really going to lose a lot of dollars no matter what. It's just a matter of what he wants to do.
It really sucks a lot of ***** though, Thanks for the diagram!
Honda Newb
so I pulled the warmer and blew some air through the trans line while plugging the other end, heard air leaking through the coolant opening. so i guess that's the culprit.
What do you guys think could have caused this to happen? Could it just be a faulty part?
that new "atf warmer" seems very iffy to me. no idea why they went that route instead of the usual sharing the radiator (which has issues as well but is proven over the long term).
Honda Newb
it must be a decent design, being that I'm the only one you guys have heard of this happening to.
A reman trans should come attached to a new cooler.
EDIT: Yeah, you could try it. I don't see why you couldn't.
if that warmer is just bolted to the trans with a bracket, yeah take it out and use aftermarket cooler. just get a hose repair kit and join the coolant lines together (they have brass fittings that you clamp a hose to each side).
Honda Newb
You can only drain out about 2.5-3 quarts at a time. There are still about 5 (?) more quarts of that nasty stuff inside that you can't get in one try.
For as much as I frown upon machine flushes, this is actually one time where a flush machine might come in handy. You got nothing to lose except the price of a bunch of fluid, because I'm totally expecting you to need a trans no matter what.
Price a complete drivetrain, junkyard/used?
Honda Newb
That first picture was the initial pulling of the drain plug. The second one is from the first round of "flushing"
Total I used about 6 gallons of atf. Idk if that's what you meant by "machine" flush.
i would drive it around and see what comes out. even with the flush, i doubt you got all the nasty stuff out.
Honda Newb
That's a good idea, as soon as I get the new coolant temp sensors I'll drive it around a bit and do one more drain and fill. Then hopefully my brother can be back on the road in his car that can crap out at any moment lol
Honda Newb
well... she's back on the road and runnin!
All in all I replaced
Radiator
Radiator cap
Thermostat
Aftermarket ATF cooler
Ect sensor
Fan switch
Coolant
ATF
I used about 7 gallons of Atf to flush the transmission.
Total was about $300
Thanks for everyone's tips and ideas
Radiator
Radiator cap
Thermostat
Ect sensor
Fan switch
Coolant
ATF
Post back in this thread every now and then so we can see who wins the pool.....I mean see how long it lasts.
