06 Honda Civic Si - Trunk problem
Old Dec 22, 2011
tsc_mjolnir's Avatar
tsc_mjolnir is an unknown quantity at this point
Unfortunately my emergency trunk release is blocked and I cannot switch it and I took off the paneling to access the wire to release my trunk and either I'm not strong enough with a multi-tool or something else is wrong.
Also I'm getting out of the Navy and I have an appointment in five hours with my papers and records in my trunk.
Any help is gratefully and greatly appreciated!
Old Dec 22, 2011
Re: 06 Honda Civic Si - Trunk problem
Fixed it! The problem was that when I closed the trunk (which was full) it knocked the plastic actuator off axis and therefore could not release my trunk.
I was able to (with brute force and LOTS of patience) pry between my back seats with a flashlight and an aluminum broom after remembering whether it was a black or yellow pull-lever I saw something and took the chance. Pushed against it, pulled my back seat and out it came!
Before all that I had taken off the paneling, and I did not know you pop off the top area and then slide the bottom towards the front of the car (lesson learned). Regardless I had tried grabbing and pulling the actuating steel wire, but that proved useless.
Just wanted to give the whole story. Hope this helps someone else out in the future! =]
Old Dec 22, 2011
Gunner's Avatar
A true genius admits that he/she knows nothing.....CLOSED SAT/SUN
Gunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to all
Glad to see you fixed it and thank you for the update...
Civicman92296
Apr 23, 2015 09:22 PM
jessicakaybby
Apr 20, 2015 12:11 PM
dooner24
Apr 14, 2015 07:51 PM
bahena08
Apr 11, 2015 05:09 PM
trevaaaa
Oct 10, 2001 01:23 PM
