Power Steering Fluid
Re: Power Steering Fluid
whatever it gets dark instead of clear/honey color. use a turkey baster to suck out the fluid in the reservoir, put it in a disposable cup so you can measure what you took out, then get a new cup and pour clean oem honda ps fluid til it matches how much you took out. pour it back into the reservoir (it will be over the max line at first, but after you drive the car it will go down to max). you can repeat this a second time after a few driving trips if the fluid is still dark. drain and fill of the reservoir changes 1/2 of the total capacity. be careful not to spill any fluid.
A true genius admits that he/she knows nothing.....CLOSED SAT/SUN
^ agreed. You can also jack the car up and once you replace the fluid you took you turn your wheels through full range of motion..all the way left and right a few times..Or just drive it as mentioned above.
mattdoc
Mar 14, 2017 12:10 PM
RIPSAW
Nov 6, 2015 04:36 AM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
hans.pcguy
Jul 12, 2015 12:19 PM
