Code P2646 on my 2006 Honda Civic si
Old Oct 30, 2011
Adam925's Avatar
Adam925 is an unknown quantity at this point
Question Code P2646 on my 2006 Honda Civic si
I recently posted a thread https://www.civicforums.com/forums/3...ml#post4567644
After i read reply's i checked my oil added a couple quarts and took it for a drive. Runs fine, sounds fine, no loss of power, but still the Malfunction Indicator lamp on the dash. So i used a friends OBDll/EOBD Scanner and got DTC Code P2646 $0710 Generic
A Rocker Arm Actuator
System Performance or
Stuck off Bank 1
Any suggestions on the Next step?? Also should i try to reset the ECU?
Old Oct 30, 2011
lazlong's Avatar
Re: Code P2646 on my 2006 Honda Civic si
Reset the ECM first. If the code comes back check for continuity in the oil pressure switch with the ignition off. No continuity= replace the oil pressure switch. Check for resistance between the VTEC solenoid and body ground. Resistance should be 14-30 Ohms. If it isn't replace the VTEC solenoid.
Old Oct 30, 2011
Adam925's Avatar
How exactly do i reset the ECM on my Car 2006 Civic si ?
Old Oct 30, 2011
lazlong's Avatar
With the ignition OFF, pull the ECM fuse in the under-hood fusebox for at least 10 seconds.
Old Oct 31, 2011
Adam925's Avatar
There is NO Fuse labeled "ECM fuse" in the under-hood fusebox. Even in my manual there is NO "ECM" Period!
Old Oct 31, 2011
lazlong's Avatar
My bad, they changed the name of the computer AGAIN. It's the EPS.
alexkharden
Apr 23, 2015 07:13 PM
jessicakaybby
Apr 20, 2015 12:11 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
dooner24
Apr 14, 2015 07:51 PM
