Vibration--Engine Mounts???
Old Jul 28, 2011
Sonoma818's Avatar
Sonoma818 is an unknown quantity at this point
I have a 08 Civic Coupe that started vibrating in cool weather when I put the car in reverse. When I went into drive, the vibration stopped. In warm weather it was fine. Three months later, it vibrates in park, reverse and drive--in summer weather. Have been to 3 shops, and no cure. Yesterday I changed the dog-bone mount, and the problem persists. HELP!!!
Old Aug 9, 2011
raaxaa's Avatar
raaxaa is an unknown quantity at this point
Re: Vibration--Engine Mounts???
Hi. I am having the same problem in my 2008 Civic. (Infact just posted a query relating to this problem). The vibrations are most visible in Parking & Reverse gear and sometime follow in Driv gear also.
I havent done anything regarding it yet. Do you think it can be dangerous driving the car like this?
And did you find out the Root Cause for this problem?
Cheers
Old Aug 10, 2011
raaxaa's Avatar
there?
Old Aug 10, 2011
lazlong's Avatar
Which one, the front or back one? There are couple things that you can do:
1. Change the other mount(s)
2. Scan for codes. Autozone will do it for free if you don't have a scan tool.
I would personally scan for codes first just to rule out the engine or tranny codes. If no codes and it's still vibrating after you change the other mount(s) then I would say you need to have the tranny inspected. To inspect it they would have to take it apart. Meaning you might as well have it re-built 'cause it's gonna be about as expensive as a re-build.
FYI: Go on Honda-tech and look at their list of TSBs to see if this is a common problem
Old Aug 11, 2011
eaglefox12's Avatar
eaglefox12 is an unknown quantity at this point
I have the same problem with my 07 coupe... my mechanic says right engine mount needs to be replaced... doing it this weekend... not sure if i should get aftermarket or the oem... $150 vs $500...n not sure after doing that it's going to solve the issue... anyone???
Old Aug 11, 2011
500 for a mount? lol goto www.hondaautomotiveparts.com i bet its a ton cheaper. usually only the front mount goes bad anyway. and im not sure on the newer civics, but when my mount tore i didnt feel any vibrations. engine didnt quite have the power it used to, but i wouldnt have even noticed without looking at the mount.
Old Aug 11, 2011
eaglefox12's Avatar
that's with the labor... it's $250 for the mount PLUS another $250 for labor... dealers are suckers... they suck all the money out of u... lol
Old Aug 16, 2011
eaglefox12's Avatar
update... my problem's fixed after $330... dealer quoted $550...the problem was my right engine mount.. there was a crack... so depending on where the noise is coming from.. L/R... have them check the engine mount... 3 weeks.. and 3 mechanics.. no one could figure it out right... until the fourth one...
Old Oct 9, 2012
SDJerry's Avatar
SDJerry is an unknown quantity at this point
My 08 Civic just sustained a broken motot mount. Found out via the same way others have, a vibration & noise while foot on brake and transmission shifted from P to R.
My independent mechanic of 20 years replaced it, parts & labor, for $341, and that's for an OEM mount. The OEM mount has oil in it and the aftermarket is solid rubber. My guy strongly suggested the OEM as being superior in quality, which was only $70 higher in cost.
$550 seems VERY high.
Old Oct 10, 2012
petros's Avatar
petros is an unknown quantity at this point
Hi, I am in the UK and my 06 Civic Automatic iShift has recently let me down with a broken engine mount. The dealer here in states, " never had one of these fail before ".
It does seem however that quite a few people are having/have had the problem.
Since the mount has been replaced I have lost all the vibrations/juddering which I have been experiencing for some time, especially in reverse, ( I live on a hill and have to reverse uphill to leave my property) Until now I had put this down to wear and tear, but it does appear that the service agent has not discovered the cracked mount and has caused me to break down some 200 miles from home.
The cost in the UK by an official Honda dealer was £350.00 (UK pounds) plus recovery and large amounts of lost time.
The moral is, if you feel any vibrations check the engine mounts.
Old Dec 26, 2013
maximai's Avatar
maximai is an unknown quantity at this point
I had the same problem. I swear, this civic 08 model has a lot of problems. First is the driver seat sun visor. 2nd is the paint that peels off on the roof. And finally, it's the engine mount that I just had fixed for $400.
Old Dec 26, 2013
I wouldn't say that.
I've been around other brands of cars that really do have 'a lot of problems'.
There's a warranty extension for visors.
There's a warranty extension for paint.
They do that.
If you can't DIY, you pay someone else to do it.
mgrantaz
General
May 2, 2022 05:40 PM
Mad Dog Tannen
Oct 19, 2016 08:12 PM
twd000
Oct 4, 2015 12:52 PM
jackoncruzpr
Sep 29, 2015 07:59 PM
FistRock
Sep 4, 2015 08:00 PM
