FS: Rebuilt Honda D16Y5 1.6L Engine 1996-2000 Civic NON VTEC SOHC VTEC-2 $1300
Old Dec 1, 2020
steveDC5's Avatar
steveDC5 is an unknown quantity at this point
Hi, for sale is a fully REBUILT Honda D16Y5 engine. This was pulled from my friends 98’ Civic HX Manual. (This engine had absolutely ZERO damage or significant wear when disassembled. It was from a properly maintained family owned car. The rebuild process and parts list is below.)
Price: $1300 OBO
Engine Serial: D16Y5 (1HGEJ712WL004826)
The engine has been FULLY REBUILT with a full OEM-spec “EVERGREEN” rebuild kit. To complement these new parts the cylinder head was professionally skimmed, hot tanked, and given a touch of new paint. Along with this the block was cleaned on the outside.The full rebuild was done along the manufacturer’s (dealer’s) procedure. Every part that was reused was cleaned before reassembly. The new piston rings were clocked correctly. The cylinder head was fully rebuilt (valve stems were not knocked out). All valves lapped in. The complete v-tec rocker assembly was disassembled, inspected, and reassembled. The engine block was completely stripped and the cylinders honed. The new pistons and wrist pins were professionally installed on the cleaned connecting rods. The entire engine was rebuilt using assembly lube and bearings gap-checked with plastigage. The timing is set correctly with the new timing belt. The Engine has no fluids. Below is the full parts list and terms of sale. Other Remanufactured D16Y5’s are incredibly more expensive and also lack components such as: (oil pan, valve cover, timing cover, crank position&temp sensors, motor mount, crank pulley, oil strainer, distributor, spark plugs&wires, filter etc.) Everything that is on the engine (see pic 1) is sold with the engine (no stand). There is NO WARRANTY on this Engine. This rebuild was done very meticulously and I have pictures of every step, as well as recipes for all the parts. Below I have linked a public imgur album of extra pics from the rebuild process for you to reference. If you have any questions or hesitations whatsoever please contact me.
LOCAL PICKUP ONLY in Santa Monica, Los Angeles California, 90405.
The NEW parts include (link to full rebuild kit used: https://www.ebay.com/itm/Overhaul-En...2649#vi-ilComp)
Full Gasket Set (Multiple Layers Steel (MLS) Head Gasket, Valve Cover Gasket, Valve Stem Seals, Intake Manifold Gasket, Other Small Gaskets. RTV where required) Every gasket was replaced.
New Pistons
Wristpins
Piston rings
Crank bearings
Thrustwashers
Timing Belt
Timing Belt Tensioner
Water Pump
Oil pump
Rear Main Seal
Oil Filter (WIX)
Imgur Album (Rebuild Pics): https://imgur.com/gallery/LJmBhca
Thanks for your interest in my auction.
By Purchasing this item, You are Agreeing (READ BELOW) to the "TERMS OF SALE" as stipulated Below.
TERMS OF SALE - TERMS OF SALE - TERMS OF SALE
This sale is a FINAL SALE. NO REFUNDS. NO RETURNS. NO EXCEPTIONS.
Local Pickup: Buyer responsible for local pickup of item from an agreed upon location in Santa Monica, CA. (does not include engine stand)
By purchasing you are agreeing that you have fully read the description and looked at the images. You have the opportunity to reach out if you have any questions BEFORE the sale.
References: honda civic del sol orignal oem stock d16 d16y5 d16y8 japanese quality manual civic ex ek dx cx lx hx s si gx type r crx delsol plug power volts 12v coupe sedan hatchback 2 door 4 door stick shift jdm transmision part quality free shipping fast quick engine del sol integra part number honda system product genuine mpg coupe hatch vtec e-vtec 1996-2005 1996- 2005 1992 1993 1994 1995 1996 1997 1998 1999 2000 2001 2002 2003 2004 engine rebuilt motor honda valves d series d-series new rebuilt remanufactured.
Old Dec 1, 2020
FRSam's Avatar
Click Here
Re: FS: Honda D16Y5 1.6L Civic Rebuilt Engine 1996-2000 NON VTEC SOHC VTEC-2
Please post price as per forum rules, unless I’m blind and it’s posted there.
Are there any refunds, returns, or exceptions?
Old Dec 1, 2020
steveDC5's Avatar
Price posted.
tbschmitt
Aug 25, 2020 08:45 AM
alicia9274
Dec 19, 2013 03:10 AM
Alpha 5
Aug 21, 2009 04:40 PM
cdmx
Dec 16, 2006 01:41 AM
jgoodfella1
Mar 5, 2005 10:15 PM
