Interior light problem
Old Nov 13, 2010
Bugman1400's Avatar
Bugman1400 is an unknown quantity at this point
I have a '98 LX. My interior light comes on when I switch it to ON, but I get nothing when I switch it to DOOR. I've tried all four doors and nothing. I then used an ohmmeter to ohm out the door switches and the plungers are fine. I then pulled the interior light and the ground wire (white,red,green) does not ohm out to ground (with the doors open). Does anybody know where the ground wire goes when it leaves the overhead interior light? The driver's door switch has a smaller green wire so, it must connect up to the larger white,red,green wire somewhere. I've also noticed that the rear doors have a larger white,red,green wire similar to the interior light ground wire.
Mucho thanks!
UPDATE: It shows in the Honda Civic Service Manual that the wire harness from the interior light travels down the driver's side pillar to the leftside dash somewhere. I will look there and report back what I find.
Old Nov 14, 2010
CraigW's Avatar
Re: Interior light problem
Is the head unit original or aftermarket ??
Old Nov 14, 2010
Bugman1400's Avatar
Aftermarket...why?
Old Nov 14, 2010
CraigW's Avatar
The 6th gens dome circuit is tied into the factory audio system (for whatever reason Honda had ?)
There is info some place about adding a jumper in the audio harness wiring to re-enable it.
Old Nov 15, 2010
CraigW's Avatar
http://www.google.com/url?sa=t&sourc...wCkYi_DCEyq7fg
Old Nov 20, 2010
Bugman1400's Avatar
Did the mod and it worked great! Much thanks!!
CarStuff
Dec 6, 2020 12:52 PM
werdnahall
May 17, 2015 11:37 AM
tylerginevan
Apr 27, 2015 12:29 PM
dooner24
Apr 14, 2015 07:51 PM
supercivic01
South
Nov 30, 2001 11:27 AM
