DIY Electrical issues troubleshooting
Old Jul 27, 2022
some of our cars are getting very old, so wiring health is important to check. Also, previous owners/mechanics could have done a hack job and they could be undoing themselves. Heat will reduce conductivity and make poor connections worse. You will need to check things yourself, unless it is a very common occurrence on the generation of your car.
First off, try to get a repair manual - they have electrical diagrams.
*not complete, still under construction* - feel free to add more tips, BTW.
Questions will be removed from this thread to keep it clean as a guide
  • Check fuses
    • don't just look at the fuses, pull them out and check.
    • there are two boxes, one under the dash, another in engine bay, check both
    • don't know which fuses to check? Don't let this hold you back, how many fuses are there anyway? Check all
  • Check grounds - there are three main grounds
    • if loose, tighten
    • if dirty, remove and clean
    • if wires damaged, fix them
  • Battery draining
    • Have someone check the health of (Autoparts stores can do this)
      • Battery
      • Alternator
    • With multimeter, check draw at each fuse in the fusebox
      • keep all power off
      • pull fuse out
      • put multimeter and connect
      • check if there is current draw
      • if draw found, start checking that system's wiring - most likely something is damaged and shorting
  • intermittent electrical issues, dash suddenly lightining a Christmas tree with multiple check code (VSA, EPS usually in there) (8th gen and above)
    • Low electrical power wrecks havoc on electronics.
    • Loose grounds
      • remove, clean and re-tighten
    • loose battery terminals
      • don't just look at them - remove, clean and re-tighten
      • one member found out a hidden bolt that was not tightened, that's why we say remove
      • if corrosion (green/blue-ish material accumulation), clean them
    • Not charging - need to check why
      • autostores can test alternator
      • note that aftermarket alternators are famous for not working properly on hondas
    • battery failing
      • auto stores can test batteries
    • wire harness damage (rodents again)
    • parasitic draw
  • 7th Gen cars ECU does not connect, alternator does not charge
    • Check if your alternator bolts are tightened.
      • When loose, the alternator have poor ground and the intermittent connection will fry the ECU!
    • ELD can cause not charging. One member went to a junkyard and pulled as many LED as he could get and installed them until it worked.
  • Door controls not working (power windows, power locks)
    • Don't jump into new actuators!!!
    • the wires at the door hinges could be damaged.
      • Constant open/close will stress the wires at the hinges and get damaged
      • open the door as much as you can, pull boot and start inspecting
    • wires OK, you can start checking other items.
Jeff Thies
Jul 16, 2017 04:47 PM
Kupó Moguri
Apr 8, 2017 11:40 AM
