Help car not cranking
Old Mar 27, 2020
Brandonhb28's Avatar
Brandonhb28 is an unknown quantity at this point
I have a 97 hatch with b18 in it . I swapped the entire engine harness even the inside harness because the wiring was torn .. the starter clicks but doesn’t turn the flywheel because the injectors aren’t firing because the wires to them aren’t getting power . I used a light tester and the dizzy is getting lower but won’t crank the relay is working idk what’s going on not allowing my injector is to fire up the engine can someone help out plz
Old Mar 28, 2020
Wankenstein's Avatar
Re: Help car not cranking
Remove the starter and test with a battery and jumper cables or bring to parts store and have them test it. Make sure the starter is functioning correctly and then move on from there.
Do you have the correct ecu for your engine?
Old Mar 28, 2020
mac25's Avatar
Dr Krieger of Modification
Starter shouldn't click. Usually it does nothing or makes the starter sound the beginning sound while starting a car, err err err err.
clicking is usually battery related.
-dead battery
-loose connections at battery terminal
-disconnected grounds
Old Mar 28, 2020
single click or multiple clicks?
If it's multiple clicks, I"d venture a guess it's battery related. Battery dead, bad grounds, etc.
Single click, I'd look to the starter for the issue. Try smacking the ever-living **** out of the starter motor and try again. Still no dice? Prolly bad starter
SleeperGS
Sep 1, 2016 07:41 PM
zetsueix
Jan 14, 2015 04:39 PM
hondahillbilly
Mar 6, 2012 04:38 PM
blasianboy
Oct 21, 2011 07:35 PM
jamescardenas07
Feb 12, 2005 12:56 PM
