2006 Civic Hybrid brake keeps locking
2006 Civic Hybrid(with $98K mileages( IMA light and check engine light are on. Car runs good for a few minutes; sometimes more than 20 minutes if I disconnect the car's battery. After 10-20 minutes, D light dispears for a few second and comes back on. At that time car jumps a little. Then after 2-3 minutes, "Brake System" light(yellow) would show in the dashboard and brake would lock. It happened few times. I had to disconnect the car's battery few times to drive about 10 miles to come home. It is not safe to drive like this. Honda dealer says IMA is deteriorating and PMC needs to be replaced. Dealer would charge $1600 to replace the PCM and about $2800 to replace the IMA battery. I think it is not worthy of spending so much. Another mechanic ( who is a honda specialist) said PCM is good, but IMA is deteriorating. However, neither Honda dealer nor the honda specialist mechanic could tell me why brake keeps locking. I bought a new (car) battery (151R with 340CCA) from Autozone. It ran good for about an hour with no problem( no D light dispearing, no brake system light on, no brake lock, no jumping, etc). Now it started doing the same thing. Please help me. I cannot afford to buy another one. I realized that if I leave the car's battery disconnected overnight and if I don't use A/C, then it runs better for a little longer. Thank you, guys. I reall\y appreciate your time.
Re: 2006 Civic Hybrid brake keeps locking
hello! I am having this same issue. Did you find the source of the problem?
CanadaJimmy
Sep 21, 2018 10:51 AM
wutsausername
Mar 26, 2018 12:21 PM
nitroturf
Mar 13, 2012 12:44 PM
