Dashboard and lights....
I recently just got a 2003 Honda Civic. After buying it my dashboard lights and and the gauges stop working. They will flicker on every once in awhile but thats ever so often. Pull the dash apart there's no wires behind it that are disconnected or anything I was told to check the wiring underneath the seat and they are fine. I don't know what else to check I've been told to check the headlight switch but I'm not sure if that's just the whole toggle switch for headlights and blinker or if that's a different individual switch.
Re: Dashboard and lights....
I'd pull the cluster out, turn everything on, and wiggle its harness connectors while observing the gauges and lights to see if that makes any difference.
okay i just tried that and still nothing except the BRAKE light is still on. But thats been on since i bought it. And when i turn on my high beams the indicator shows on the cluster
Might be time to get a good wiring diagram and a voltmeter, figure out what's missing?
That's why I suggested wiggling the gauge cluster harness connectors, on the off chance one of those was the problem.
Derek Wall
Nov 27, 2016 04:51 PM
What_It_Do
Jul 18, 2014 07:45 PM
Engineered69
30
Oct 6, 2013 03:19 PM
quattro
Jul 7, 2009 10:42 AM
