How to jump fan wire
Re: How to jump fan wire
unplug the sensor on the thermostat housing and stick a paperclip in it.
you really should fix your issue though. this is more of a "might get you home" kinda trick
What part do I stick paper clip in?? I’m actually trying to make the fan come on when I start the car and always run while driving every time not only when car gets to a certain temp hints why I’m trying to figure out how to make a jumper wire
it's a two prong connector. you just unplug it from the sensor and stick the paperclip in the connector that is attached to the wiring.
you're going to seriously reduce the life of your fan having it run constantly. say if it were to last 6 years, you might reduce that to a year or less.
Sooooo it loses coolant and runs hot? Is that why you want the fan to run all the time?
Find and fix the real problem instead of hacking the fan to hide the problem.
You will dramatically shorten the service life of that fan motor if it runs all the time.
Alehman85
Dec 7, 2017 07:50 AM
Hank714
Oct 7, 2016 12:35 PM
Californication
May 15, 2012 03:30 PM
specks
Sep 4, 2004 09:46 PM
