Dimmer switch/gauge lighting - not the typical problem
Hello all,
First let me say I've checked the basics here.
Problem:
The dimmer switch seemed to be going bad. It wouldn't work at all (no back lighting), but then you could squeeze/manipulate it and it would work.
I assumed this meant the switch was bad.
I purchased a new switch.....same problem, but nothing works.
I tested the red, black, and red & black wire for power/ground.....nothing there.
I'm wondering wtf is up? lol
Disclaimer: I did try using a paper clip to "jump"/"eliminate" the switch so that it'd be on full when on. No success. (I did connect the two ends in several ways before realizing it should just be to the black, and the red, wires/terminals.)
SOOOO.....
I'm wondering if there is a fuse blown? I couldn't find anything showing a fuse linked to this item & do not have an electrical diagram. THOUGHTS???
I'm working second shift, and am getting tired of using a small flashlight to see my gauges. lol
Any help would be appreciated.
Thank you
-Ben
Problem:
SOOOO.....
Thank you
-Ben
Re: Dimmer switch/gauge lighting - not the typical problem
I can't help with the problem, but in the meantime when it is dark, set your smartphone for a long delay on the screen shut off, and just open a Google browser, and lay your phone in front of your instruments.
Serious troubleshooters will want to know the year of your car.
All I have to offer is what I have learned in the short time I have been here.
The dimmer circuit works by increasing/decreasing resistance to the negative side of the lighting circuit.
From ezone in a thread where I was installing a voltmeter:
Originally Posted by ezone
The reason was that the car uses a variable ground to control dash light brightness instead of using a variable positive like many other cars..
If your gauge lighting is connected to ground and you hook it to the dash light circuits it can ruin the circuit board on the gauge cluster.
We see this happen after sooo many radio installs it isn't even funny, I thought it best to check out the unit further before a disaster happens..
What new switch did you buy? I am not seeing one in the parts fiche (for my 2002).
I am thinking it is part of the instrument panel cluster. I could be wrong, but I am not seeing a "switch" (potentiometer).
https://www.hondapartsnow.com/Page_P...steon&Diagram=
What year/model is your car?
SOOOO.....
SOOOO.....
Have you checked if the park/tail/license lights on the outside of the car also quit?
Is it JUST the lights in the gauge cluster affected?
Do the switches around the dash/heater panel/cruise/defog/radio still light up?
If it's all of the dash lights and only the dash lights out, use a jumper to bridge the red wire to black wire at the dimmer (unplugged) for full brightness.
Thanks for the replies guys.
The car is a 2000 ex. The dimmer switch is right below the driver's side air vent, next to the cruise control button.
Just as an example:
http://www.ebay.com/itm/1996-2000-HO...tZi-KR&vxp=mtr
Ezone:
For this year civic, the cd player, heat controls....that whole area....are connected to the dash lights it seems. When one would go out...all would go out. All exterior lights are o.k.
I'm betting your right about the fuse, i'll check it and repost asap. *crosses fingers* OMW to work now. I just couldn't find what fuse would be linked to this. I was checking them one at a time, and thought F this. lol
Just as an example:
Ezone:
Ok, I HAD to check......lol.....FUSE #30 IS THE WINNER!!!!!! It was destroyed.
THANK YOU very much all. I'll be able to drive home and see my gauges properly now. lol
On a side note......
I broke the little metal clip that holds the interior fuse panel cover. Does anyone know where to find these little buggers? I don't think the auto parts stores have them, or the local hardware stores. I'd rather not go through Honda and pay $10 for a $0.05 part.
THANKS AGAIN!
THANKS AGAIN!
THANKS AGAIN!
THANKS AGAIN!
Nah, it's nothing "serious." But it annoys me when things aren't as they should be. lol Hence a panel missing because I can't close it.
Yeah, I can check a junkyard I suppose. Well, i'll poke around and see what I can find. The important thing is that my gauges, and all the "center controls" are lit up again!
Thanks again!
Thanks again!
