Gauges keep flickering when i start engine.
Old Jun 24, 2016
pdegale's Avatar
pdegale is an unknown quantity at this point
Hi have a 2003 civic i took out the factory radio and installed a clarion it did not work, put back the old radio that did not work again ,upon checking i was not getting constant 12 v ,now when i start the car i notice my gauges start flickering and stop after a few sec ,also when i lock or unlock my car with the key the dome light normally come on now it ,i check all the fuses under dash and under hood all good can some one help please.
Old Jun 24, 2016
Re: Gauges keep flickering when i start engine.
Disconnect radio and recheck.
If you wired up the 'illumination' wires, disconnect them. Most aftermarket radios can't use those and will burn out the circuit board on the back of the gauge cluster.
Old Jun 24, 2016
CraigW's Avatar
"backup" fuse & yes isolate those dimmer leads.
Old Jun 24, 2016
"backup" fuse
Oh yeah, that.
Crimson
Nov 3, 2015 06:53 PM
redrocket87
Nov 1, 2015 07:15 PM
sshoi
Exterior
Oct 29, 2015 11:09 AM
R Steele
Oct 22, 2015 05:09 AM
TropiKalCiviC
Sep 25, 2001 07:02 PM
