automatic shifter lights
Old Feb 20, 2016
rcode's Avatar
rcode is an unknown quantity at this point
does the shifter bezel have lights in for night driving with an automatic in a 03 civic si coupe thanks ...lee
Old Feb 20, 2016
Re: automatic shifter lights
SI with auto trans must be Canadian eh?
=USA EX
I believe there should be a small light bulb.
Old Feb 21, 2016
rcode's Avatar
thanks for the reply/info and yes canadian lol . do you know how to take the bezel off to get at it for replacement.also i see you have great knowlege about these cars would you know the part numbers for the factory rear spash guards for a 2003 canadian si coupe because we are missing the pass rear ....thanks lee
Old Feb 21, 2016
You might be able to fish the bulb out if you remove the trim around the shifter, but it might be simplest to remove the entire center console off the floor then you can get to the bulb easily.
Splash guards....I've got a US catalog that says the set is not available anymore (USA 04 coupe EX).
Check your local dealership?
Junkyard?
www.car-part.com
Old Feb 22, 2016
rcode's Avatar
thanks ...i was hoping to get the part numbers so i could track some down maybe they have some identifying numbers on the inside of the guards but i will keep looking...lee
Old Feb 22, 2016
I have the part number for the set of 4 for a USA car (no individual part numbers) but the set number was not valid when I entered it into the Torontohondaparts site.
jdawgzcivic
17
Feb 1, 2020 04:16 PM
roman666c
Oct 6, 2015 10:27 PM
Sep 27, 2015 11:33 AM
speedlever
Sep 24, 2015 07:18 PM
RSKtakR
25
Sep 14, 2015 07:43 PM
