2002 Civic keeps blowing ingnition Coil Fuse
Old Jul 18, 2015
Civic65's Avatar
Civic65 is an unknown quantity at this point
I'm hoping that you guys can help a newbie out! On my 2002 Civic LX the ignition coil 15 amp fuse keeps blowing. It will run fine. Turn it off, cranks up fine and runs fine multiple times. Then turn it off and try the next day and it blows the fuse and won't crank. Try it again and it just turns over trying to start. Change the fuse, cranks and runs fine. Any advise would be much appreciated!!
Old Jul 18, 2015
emich's Avatar
emich is an unknown quantity at this point
Re: 2002 Civic keeps blowing ingnition Coil Fuse
Check the coils and replace only the bad one. http://troubleshootmyvehicle.com/honda/1.7L/how-to-test-the-ignition-coils-1
Old Jul 18, 2015
Wiggle harnesses with it running and see if it stumbles or blows the fuse...there's a lot of wire between the fuse and the coils
Old Jul 19, 2015
Civic65's Avatar
Thanks a lot for the suggestions! I will be testing everything shortly and will update. Anything else I should look at?
CarStuff
Dec 6, 2020 12:52 PM
usajags84
May 10, 2015 08:11 AM
shaejb15
Apr 26, 2015 07:44 PM
smmahan
Apr 15, 2015 08:17 PM
CapYoda
Nov 11, 2001 05:17 PM
