Headlight not working after replacement
Old Jun 8, 2014
weifert's Avatar
weifert is an unknown quantity at this point
Hi All,
A couple of days ago the driver-side headlight (low-beam) on my 2014 Civic went out. I bought a replacement and installed it today. However, when I turn on the lights, that headlight still won't come on.
Is this something more than just a dud headlight?
Thanks.
Old Jun 8, 2014
Re: Headlight not working after replacement
2014 Civic
That should have been covered under warranty.
Old Jun 8, 2014
Unless you meant 2004.
Then I suppose you could have got a bad bulb, you could have put the old bad one back in by mistake, you could have wiring problems, bad socket, or blown fuse, or any of several possible causes that would keep a headlight form working.
Old Jun 8, 2014
weifert's Avatar
I did mean 2004. My apologies. I haven't thought to check the fuses. Would a blown fuse only keep one light out?
Old Jun 8, 2014
Sure. Maybe.
Do both high beams work?
Old Jun 8, 2014
weifert's Avatar
Both hi-beams do work.
Old Jun 8, 2014
OK then the two fuses should be ok, and the headlight relays should both be ok.
That leaves a lot of wiring, a ground, connectors, and the bulb as possible suspects.
A wiring diagram, a voltmeter or test light, and some sleuthing could solve this.
ORskier
May 3, 2015 12:54 PM
bsmiley
Apr 27, 2015 01:27 PM
shaejb15
Apr 26, 2015 07:44 PM
thesushiboy
Apr 12, 2015 02:54 AM
SWEETRIDE
Nov 27, 2001 05:52 PM
