check antenna
Old 12-20-2012
kschmett's Avatar
kschmett is an unknown quantity at this point
check antenna
I tried to activate the XM radio in my new 2013 Civic EX-L with navigation and it will only say check antenna. What should I do? There is nothing in the manual for this.
Old 12-20-2012
Re: check antenna
The XM has an antenna problem.
Return to the dealer for warranty.
Simple.
The XM should already be activated AND WORKING with the 90 day (?) free trial. I'd wait until that runs out before paying for it.
Old 12-20-2012
kschmett's Avatar
Re: check antenna
Thanks, I will call the service department. Just thought there might be a fix I could perform at home.
Old 12-21-2012
kschmett's Avatar
Re: check antenna
It was an unplugged cable in the trunk. All is well. Thanks for the response.
Old 12-21-2012
Re: check antenna
I'm curious because I haven't had a chance to see where the wiring is run.
Was this a factory build error (problem), or was this something you could have inadvertently bumped with luggage or groceries or something?
Old 12-21-2012
kschmett's Avatar
Re: check antenna
I hadn't used the trunk for anything so it had to be a factory error. The tech said that the cable just wasn't fully plugged in. It is working great now.
HX
12-28-2001 10:04 AM
Micks2K1
12-06-2001 07:09 PM
delacampos
11-07-2001 09:18 PM
dubbc
11-07-2001 02:24 PM
GoofyLogicInc
10-25-2001 09:50 PM
Quick Reply: check antenna
