2 way speaker mod..Got a question for the pros
I bought the mid price pioneer 2 way speakers for my car. I'm having a hard time balancing the range frequencies.
My question is, would it be possible to cut the tethers to the tweeters on the speakers. Getting a little sick of all the highs!
Re: 2 way speaker mod..Got a question for the pros
I have the same speakers, i had the same problem with them before the amp, are you just running them off the head unit?
People have a misconception about audio. More power isnt just to make it louder, it improves the sound quality. Right now you're getting less bass than your stock speakers bc the new speakers are designed to handle 50w and you're only feeding them 20ish if youre lucky. Bass takes the most power to reproduce since it has to move the voice coil the furthest. Since your speakers are getting 20 watts, it has no power to move the voice coil and make the bass, this is why your highs are coming through so strong.
A decent amp will cost you 75-100 dollars and it's well worth it. Without an amp, you'd be better off with your stock speakers if you're looking for better bass
You can disconnect the tweeters but you will lose all frequency on the high end. It will sound worse than stock. You can cut the treble through the head unit but you will never get really good sound from a stock unit. An amp or after market unit will make a huge difference.
My head unit allows for adjustment for mid-high, high and ultra high frequencies allowing for fine tuning to my tastes.
Dangerousjordan
Jul 28, 2015 08:24 AM
Nalmonte
Jul 22, 2015 09:08 AM
