LoJack and other anti-theft devices
I've done alot of research about an 2000 civic si and i found out how often they get stolen. I cant get lojack right when i get the car so i got a list of what i want to do to my car to reduce the chances of it being stolen. My first purchase is probably going to be a pedal jack and have it setup on the clutch. but ultimately i want a lojack system and i want to know if anybody had experiences using one to retrieve a stolen vehicle, or any other anti-theft devices they use on there cars.
Re: LoJack and other anti-theft devices
If you have any questions on LoJack or want to get in touch send us an email to corporatecommunications@lojack.com or simply give us a call at 1-800-4-LOJACK
Thank you for considering LoJack to protect your vehicle.
Jason A.
http://www.lojack.com
http://www.autotheftblog.com
I would get a really nice alarm system like a DEI Viper with shock and tilt sensors. They have 2 way remote systems that let you know when a sensor has been tripped. By the time they locate your car it will be in pieces, I would rather stop the theft from the start.
I agree with this. There are only 27 states that have police units equipped with tracking systems, and even then they must be within 3-5 miles of the vehicle. It will most likely be stripped by the time they get to it.
loud systems are still better than chains and stuff like that.
I had a huge tempered lock type system in my car back in my home country, but the guy saw through it because i did not have a loud alarm system, so he had all the time in the world to saw through it (it was quite a sturdy system, BTW).
no alarm will matter when the tow truck comes. if they want it, they will get it. alarms are completely useless and an amateur can disable it in seconds. even door locks can be opened quickly using basic tools. the only things that will deter non tow truck theft is a locking wheel boot (like the city uses), or pulling random wire harness from under the hood for ignition and fuel injectors hoping they wont open the hood and check. but again these only work once and they will be back to get it later. just get something with a lower theft rate. im no thief but i could be inside your car in 10 secs using an ice scraper and coat hanger, have your hood open and siren disabled in another 5 seconds, then im free to steal anything in the car with nobody even looking. if i really wanted to, i could fiddle around with the alarm wiring under the dash and bypass the starter kill relay in under a minute.
here are the best things i would do to try and keep thieves out of your car. if you do enough of these things, usually they will not bother or give up and go somewhere else unless they are serious about taking the whole thing
-if you have power door locks, unplug all the switches. it is much harder to gain entry into a car with manual locks.
-do not leave anything in plain sight, not even a penny. in fact if possible, do not leave anything in the car period.
-keep the radio stock, or if you must have aftermarket make a block off plate to cover it (taking the face off doesnt help).
-if you are in a bad area, unplug the spark plug wires and fuel injectors but make it look like they are still plugged in by loosely fitting them together.
-never disable your interior hood and trunk release levers unless you want major damage from a crow bar because they think you are hiding valuables. same with locking the glove box. they will get in anyway, so instead refrain from putting anything in there.
h4ldol
Apr 24, 2017 08:16 PM
