Question About amp/sub
Old May 14, 2010
dpsht316's Avatar
dpsht316 is an unknown quantity at this point
I currently have an Dual xpa4640 600W amp with a dual 12" 500W SD12 sub hooked up in my car. The LOC is wired via the wiring diagram from http://www.the12volt.com/installbay/....asp~TID~86090 the amp turns on and the sub kicks a little but can barely hear it. I have tweaked with the dials on the amp and LOC with no luck. Do any of yall have any ideas what I should do to get it to kic hard or will that combination not work correctly? I have the one sub bridged between channel one and channel two.
http://dualav.com/mobileaudio/xpa.php Link to amp
http://dualav.com/mobileaudio/sdseries.php Link to sub
Old May 15, 2010
electric130's Avatar
Re: Question About amp/sub
most LOC's have gain adjustments on them. make sure those are turned up max. then use your amp gain. probably need a tiny #0 phillips screw driver. that's how small mine were.
Old May 15, 2010
dpsht316's Avatar
All of the gains are turned up all the way. Though I found out the RMS of the amp is only 150 and the sub RMS is 175 how big of a difference would that make sound wise?
Old May 16, 2010
you'll probably have some bass, but not as much. i had a 300w amp on a 150w sub and it pounded without the gain all the way up. that amp died and i bought a 150w amp thinking it would be perfect for the sub. i had to leave the gain all the way up and it still wasn't as loud as before. so that may be your problem.
robjcivic
Mar 12, 2017 12:10 PM
JMKendrick
Sep 16, 2015 06:17 PM
Bricoleur
Sep 9, 2015 12:23 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
junkyardguy
Sep 2, 2015 06:07 PM
