amp fuse keeps blowing out
Old Feb 15, 2009
wallabee09's Avatar
wallabee09 is an unknown quantity at this point
when i got the car everything was hooked up the way it should've been. the only issue is the fuse keeps blowing in the amp to my sub. no wires are crossing nothings loose. i've even changed from the 20-30 but went back to 20 not trying to blow the amp out. it started to work a lil then blew out and i've been going back and forth. theres no shortage anywhere to be found. now when i replace the fuse and turn the car on it'll pop automatically and not even work. i've messed with the settings and thats not helping either...
any suggestions?
Old Feb 15, 2009
electric130's Avatar
Re: amp fuse keeps blowing out
replacing a fuse with a larger one is just begging to create an electrical fire. fuses are sized based on the wire size. putting a larger fuse in will allow more current to flow through the wire than it can handle. it will get hot and possibly catch fire. fuses are there to protect the system when there's a problem. if the fuse blew, you have a problem. if it blew multiple times, then you definitely have a problem. for a fuse to blow, power has to get shorted to ground. so somewhere, you have a wire or component that is shorting out.
that said, if the fuse that's blowing is the one on the amp, your amp is likely bad. if its the fuse on the battery, then you've got a wire shorted somewhere. if it's the battery fuse, try swapping out with another amp. if the fuse doesn't blow, then your amp is bad. if it does, you have a wiring problem somewhere. try that first then report back and i'll help more if needed.
Old Feb 15, 2009
wallabee09's Avatar
alrighty appreciate it i'll be looking into that today.
redcloud
25
Aug 12, 2015 01:23 PM
adamdrives
15
Aug 8, 2015 08:53 PM
exiled1
Aug 8, 2015 06:09 PM
Civic65
Jul 19, 2015 10:13 AM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
