HELP me CEL plz. code inside
Old Mar 10, 2008
CIVIC X3's Avatar
CIVIC X3 is on a distinguished road
So few weeks ago, a CEL came on and i went to my mechanic and it turns out my spark plug was not tighten down causing cylinder 1 to have a blow coilpack as well as a fried spark plug. After he fixed that problem. i still hear a tapping noise afterwards. mostly when i'm accelerating. So i went back and he said it was nothing to worry about. Now the CEL came on again. This time he said he cant fix it because he doesnt know how. He did help me run the code though, and it came out:
P2646 - rocker arm actuator.
at first i thought i needed a valve reajusted because of the tapping, but now i have no idea. any help would be nice. ty
Old Mar 10, 2008
speedfoos's Avatar
Re: HELP me CEL plz. code inside
Rocker arm actuator.....you got a VTEC head? Let me do a little research real quick.
Old Mar 10, 2008
speedfoos's Avatar
Give this sequence to your mechanic. Alternatively, check your oil level (seriously), top it off if needed and then pull the VTEC solenoid off (three 10mm bolts) and clean the little screen inside. Reset the ECU, and see if it's any better. If it's not them take this sequence to your mechanic and have him follow the steps. You may have to take this to a dealer though...
DTC P2646: VTEC Oil Pressure Switch Circuit Low Voltage
Special Tools Required
Pressure gauge adaptor 07NAJ-P07010A
A/T low pressure gauge w/panel 07406-0070300
A/T pressure hose 07406-0020201
A/T pressure hose, 2,210 mm 07MAJ-PY4011A
A/T pressure adaptor 07MAJ-PY40120
Oil pressure hose 07ZAJ-S5A0200
1. Turn the ignition switch OFF.
2. Check the engine oil level.
Is the level OK?
YES - Go to step 3.
NO - Adjust the engine oil to the proper level.
3. Turn the ignition switch ON (II).
4. Reset the ECM/PCM (see HOW TO RESET THE ECM/PCM ).
5. Start the engine. Hold the engine speed at 3,000 rpm with no load (in Park or neutral) until the radiator fan comes on, then let it idle.
6. Test-drive under these conditions:
Accelerate in 1st gear to an engine speed over 5,000 rpm. Hold the speed for at least 2 seconds.
Is DTC P2646 indicated?
YES - Intermittent failure, system is OK at this time. Check for poor connections or loose terminals at the VTEC oil pressure switch, at the VTEC solenoid valve and at the ECM/PCM.
NO - Go to step 7.
7. Turn the ignition switch OFF.
8. Remove the resonator (see RESONATOR REMOVAL/INSTALLATION ).
9. Remove the VTEC oil pressure switch (A), and install the special tools as shown, then install the VTEC oil pressure switch (A) on the oil pressure gauge adapter.
NOTE:Install the part in the reverse order of removal with a new O-ring.
10. Disconnect the VTEC solenoid valve 1P connector.
11. Start the engine. Hold the engine speed at 3,000 rpm with no load (in Park or neutral) until the radiator fan comes on, then let it idle.
12. Attach the battery positive terminal to VTEC solenoid valve 1P connector terminal No. 1.
13. Start the engine and check the oil pressure at an engine speed of 3,000 rpm.
Is the oil pressure above 390 kPa (4.0 kgf/cm2 , 57 psi)?
YES - Go to step 14.
NO - Inspect the VTEC solenoid valve (see VTEC Solenoid Valve Test ).
14. Disconnect the VTEC oil pressure switch 2P connector.
15. At the VTEC oil pressure switch side, check for continuity between VTEC oil pressure switch terminals No. 1 and No. 2 with the engine at 3,000 rpm.
Is there continuity?
YES - Replace the VTEC oil pressure switch.
NO - Go to step 16.
16. Turn the ignition switch OFF.
17. Disconnect the battery terminals from the VTEC solenoid valve terminal connector.
18. Disconnect ECM/PCM connector B (24P).
19. Check for continuity between ECM/PCM connector terminal B9 and body ground.
YES - Repair short in the wire between the ECM/PCM (B9) and the VTEC oil pressure switch.
NO - Go to step 20.
20. Check for continuity between ECM/PCM connector terminal B15 and body ground.
YES - Repair open in the wire between the ECM/PCM (B15) and the VTEC solenoid valve.
NO - Go to step 21.
21. Connect the VTEC solenoid valve 1P connector terminal No. 1 and body ground with a jumper wire.
22. Check for continuity between ECM/PCM connector terminal B15 and body ground.
YES - Update the ECM/PCM if it does not have the latest software, or substitute a known-good ECM/PCM, then recheck (see ECM/PCM UPDATING, SUBSTITUTION AND REPLACEMENT ). If the symptom/indication goes away with a known-good ECM/PCM, replace the original ECM/PCM.
NO - Repair open in the wire between the ECM/PCM (B15) and the VTEC solenoid valve.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
raynist1
Jun 23, 2015 02:03 PM
juror
May 26, 2015 06:35 PM
Fastfebur
Apr 26, 2015 11:57 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
