HELP! After CD Player Install, NO Illumination
Old Mar 13, 2007
zachpolo's Avatar
zachpolo is an unknown quantity at this point
After I installed my new HU, using all wiring harnesses, I now have NO illumination of the instrument panel. So at night, I have no idea how fast I'm going, my speed, etc. etc. I have the Blue and white wire(labeled Antenna), the brown (Labeled MUTE), and the orange wires(Both pos. and neg) NOT connected to anything. What do I have to do to illuminate the cluster again??
Old Mar 13, 2007
Taffy's Avatar
Taffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant future
You might have not hooked up the Orange Illumination wires, but did you take the extra step to make sure to cover them in tape or crimps? If left bare they could touch metal and ground the wire, popping the fuse to your illumination lights. So check the fuse.
Old Mar 13, 2007
zachpolo's Avatar
BOTH of the orange wires are coming from the harness I got that attaches to the factory radio, so there isn't any orange ones from the new units harness to connect to.. Or do I just connect the orange ones together even though they are on the same harness?
Old Mar 19, 2007
lil_brwn_guy's Avatar
lil_brwn_guy is an unknown quantity at this point
Don't Connect them together cause the orange wire is the 12V+ Park light wire and the orange/white is the (-)dimmer wire short them together and you will burn out the illumination switch and you will need a new cluster.
mjdiaz89
Jun 21, 2016 09:26 PM
jzhartman
22
Jul 23, 2015 10:42 PM
robbie374
Jul 7, 2015 02:56 AM
