Jensen indash brake bypass code
Crack kills... But then again... So do I...
Found this on another forum, I couldn't get it to work but maybe one of you can and relay what I'm doin wrong.
The code is a permanent way of disabling the brake override on the jensen units and you will never have to use a toggle switch or black box.
Insert the DVD
After the disc loads and plays you will see a blue screen telling you "it is unlawful to drive with a movie".
1) Activate the brake sequence and disable the blue screen using the hand brake, the switch method or anything else to give the unit its three pulses to disable that freakin blue screen.
2) Next, on the main remote press stop twice, then 1, 2, 6, 4.
You will now see a hidden menu that says:
-Region Code
-Brake Override (I know you're drooling by now)
-Macrovision (Watch all the burned and pirated movies you want if it is turned off)
-Loader Version
-Model Version
3) Using the right joystick on the unit, navigate to the options of your choice, click on them to toggle on, off or which region code you want.
This is what you want:
-Region Code: 1
-Brake Override ON
-Macrovision: OFF
When your done, click SYS SETUP on the main remote TWICE to save the settings and bingo, your done!!! Hooray!!!
I only supply this for informational puposes only; THE DRIVER IS FULLY RESPONSIBLE FOR HIS/HER OWN ACTIONS and i will not be held liable.
Insert the DVD
-Region Code
-Loader Version
-Model Version
-Region Code: 1
-Brake Override ON
-Macrovision: OFF
Ok... Bringing this back up... Finally got it to work so read up. I never have to engage my brake again.
I haven't had any problem with it at all. The only thing that's a lil difficult is getting a feel for how sensitive the touch screen is.
CarStuff
Dec 6, 2020 12:52 PM
mievil
Apr 28, 2015 11:02 PM
alienmonkey
Feb 1, 2002 11:48 AM
