duel voice coil help!!!!
I have 2 12inch subs that are duel 4ohm voice coil. My amp bridges into 4 ohms. Can someone explain to me how to wire these bad boys up!!!
Sounds like a 2-channel amplifier. I would series the voice coils into one 8 ohm load. The positive from one voice coil is wire to the negative from the other. Your positive and negative connections that remain then hook up to the bridged amplifier.
I wouldn't run them in stereo as separate channels because you don't want any chance of sending a different signal to the coils.
Can't run the voice coils in parallel for a two ohm load because most 2-channel amplifiers aren't stable bridged into two ohms.
Try out this like, the second wiring diagram should be the one you want: Rockford Fosgate® - Woofer WiringWizard
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
h4ldol
Apr 24, 2017 08:16 PM
deanaZoom
35
Sep 19, 2015 12:22 PM
RSKtakR
25
Sep 14, 2015 07:43 PM
