Notices
Wheels and Tires Post your wheel and tire related questions here.
Confuse in tires size
Old Nov 7, 2013
gozuhair's Avatar
gozuhair is an unknown quantity at this point
Hi All
I have Honda CIVIC 2005 with sunroof, automatic and when I look into my tire size so its P185/65 R15 and with 4 bolt pattern now I have a plan to buy snow tires and I'm wondering how can I very tire size before buying, actually one of the seller person told me that if the tire size is 14 inch then it also works and another person told me that if tires size is P195/65 R15 instead of P185/65 R15 then it also works. Please let me know how come I know that which tires sizes will fit into my CIVIC.
In addition, If I have 15 inch all season tires and will replace it 14 inch snow tires then does it hurt my car performance and grip. Please advice.
Regards
Muzokh
Old Nov 7, 2013
Stock 99's Avatar
Re: Confuse in tires size
I stole this from ezone muhaha...
http://www.miata.net/garage/tirecalc.html
put your standard tire on the left and play with the size on the right...if it's not a perfect match your speedometer will not read correctly.
BTW tire code is P195/65/R15
'P' = passenger
195mm wide
65 means that the size of the sidewall is 65% of the width of the tire
'R' = rim size 15"
so the difference from 195 to 185 isn't huge
EDIT - oh it has a sunroof so that changes everything. j/k
Old Nov 7, 2013
GolNat's Avatar
Prelude Owner
iPhone friendly calculator:
http://www.tacomaworld.com/forum/tirecalc.php
Old Nov 7, 2013
Stock 99's Avatar
If you keep the overall size of the 14" the same as the 15 the sidewall will be thicker and yes diminish performance. They are winter tires though...not meant for high speed or extreme cornering....that's why they don't run indy cars in the snow.
...but much better grip than all seasons at temperatures below 7C
Old Nov 7, 2013
gozuhair's Avatar
Thanks for the replies, will see your provided link and let you know. In addition, can I go for 14 inch winter tires or not
Old Nov 7, 2013
like said, overall diameter is what determines if tires will change speedo, acceleration.
maybe the 14 steelies will be lighter than a set with 15 steelies.
Old Nov 7, 2013
gozuhair's Avatar
Thanks you very much for your replies..
Misfit2613
Jul 30, 2015 09:49 AM
jzhartman
Jul 9, 2015 04:56 PM
muttleytm
Jul 8, 2015 04:13 PM
BootyDo
Jul 7, 2015 06:06 AM
Causemo
Jul 5, 2015 06:42 AM
