Notices
Wheels and Tires Post your wheel and tire related questions here.
Change in tire size for snow
Old Nov 15, 2012
roadeye's Avatar
roadeye is an unknown quantity at this point
Hello folks:
I have a 2010 with stock 195/65R15's on them and have a lead on a set of snows from a 2005 Accord that are 205/65R15 on rims. I know I would need to use hub rings but otherwise would they work (besides throwing the speedo off a bit)? Do you think going to a larger tire for snow is wise?
Appreciate your thoughts.
r
Old Nov 15, 2012
danwat12345's Avatar
danwat12345 has a spectacular aura aboutdanwat12345 has a spectacular aura about
Re: Change in tire size for snow
tread design makes the biggest difference. A crappy all season vs a good winter tire. I don't think anything bigger would be worth it if it would help at all. 205, maybe 215 is the widest you could go I think.
In sand you are supposed to lower tire pressure, what about snow?
Old Nov 16, 2012
TiggerDX's Avatar
TiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of light
Generally unless you are trying to float over snow, you want a skinny tire. That's why the old bugs did so well.
If there is a lot of snow, I will drop my tire pressure to 20 but that was when I had my Jeep and 35's. Haven't tried with the Honda yet. Haven't had enough snow to worry about.
Dropping the pressure can help, but never do it if you are running chains. You need full pressure to keep them tight.
bo_red
Apr 23, 2015 10:09 PM
Jc20unc
Dec 10, 2001 08:32 AM
NightKids2
Dec 8, 2001 05:50 AM
supercivic01
South
Nov 30, 2001 11:27 AM
