Notices
Wheels and Tires Post your wheel and tire related questions here.
broken front wheel lugs
Old Jul 26, 2012
gac22's Avatar
gac22 is an unknown quantity at this point
Red face broken front wheel lugs
After having tire blow out on 1994 Civic EX, I broke two of the studs trying to change right front tire. New stud bolts won't fit into the hub. Is there a trick to replacing these? Any advice is appreciated!
Old Jul 26, 2012
GolNat's Avatar
Prelude Owner
Re: broken front wheel lugs
Put them in the freezer overnight, so they shrink a little, then hit them with a hammer. You might need to use a press.
Old Oct 29, 2012
Tandthonda54's Avatar
Tandthonda54 is an unknown quantity at this point
It is the first time i am hearing that Put them in the freezer overnight,for shrinking a little. So i think that is a good idea
Old Oct 29, 2012
I use a flat faced (lug)nut and a stack of greased washers to pull the stud in past the splines.
Old Oct 29, 2012
TiggerDX's Avatar
TiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of light
Same as ezone. You just need to build up a layer over the stud so you can use the nut to pull them into place.
GolNat
Suspension DIY
May 12, 2022 06:49 AM
edspyhill09
Jun 12, 2016 02:45 PM
cmart1209
May 29, 2015 04:52 AM
bsmiley
Apr 27, 2015 01:27 PM
crazydragon
Nov 7, 2001 05:13 PM
