Notices
Wheels and Tires Post your wheel and tire related questions here.
Front end shudder with braking
Old Mar 6, 2010
dhawk's Avatar
dhawk is an unknown quantity at this point
I have a '06 civic and the front end wobbles when. It really applying the brakes shudders. I have put on new rotors and pads on the front and it cured it for about 5000 miles but it is back worse than ever. Now, I am wondering if I need to change the brake fluid. I also have new tires on with about 5000 miles.
Anyone else had this problem?
Old Mar 6, 2010
MelJ's Avatar
Trance Addict
Re: Front end shudder with braking
You may have warped rotors. I had that happen to my car. I'd brake and the front end would shake like mad. I changed the front rotors and changed my pads even though they weren't too worn. No problems since. You're gonna need to bleed the system anyways, so you'll need a container of fresh brake fluid.
I just realized that after re-reading it you actually did have new pads and rotors. Im at a loss then. I was just speaking from personal experience. You should've bled your brakes after the job. I'd go back and recheck your work.
Old Mar 8, 2010
dhawk's Avatar
OK, now I have changed the brake fluid and flushed the system and bled it. The shudder is better but not totally gone. So I have to date done:
1. New rotors and pads in front
2. New tires and balanced
3. New allignment.
4. Changed brake fluid and bled brakes front and rear.
I don't know what else to do.
Old Apr 7, 2010
tattooedfreak's Avatar
tattooedfreak is an unknown quantity at this point
Just answered the same question on a different thread. Had the same thing happen to me. It turned out to be the front suspension bushings.
edspyhill09
Jun 12, 2016 02:45 PM
Lopes101
Jun 7, 2015 08:04 PM
hans.pcguy
May 16, 2015 09:54 PM
pheaton
May 4, 2015 08:26 PM
GH04si
Apr 15, 2015 08:13 PM
