Notices
Wheels and Tires Post your wheel and tire related questions here.
Clunk/Knock When applying brake after reversing? Help!
Old Oct 5, 2009
Crz2's Avatar
Crz2 is an unknown quantity at this point
Exclamation Clunk/Knock When applying brake after reversing? Help!
Hi for the last couple of months my 2001 honda civic, makes a clunk/Knock like noise, it only happens after you reverse and then pull forward and apply the brake.
The clunk only happens once and its usually only after the car has been sitting for a while, applying any type of braking pressure (light or heavy) seems to trigger it. The sound is originating from the rear brakes, I've pulled off the wheel to take a look, but I did not see anything out of the ordinary.
I don't know if this is related, since this sound showed up I also hear a rear brake "squeak" every time I release the brake.
Thank you for your help!
Old Oct 5, 2009
Re: Clunk/Knock When applying brake after reversing? Help!
its normal, just the calipers and abs doing their adjustment. rear brake squeak is unrelated and very common, usually they just need to be lubed.
Old Nov 8, 2009
pspbrewster's Avatar
pspbrewster is an unknown quantity at this point
I have the same issue and I'm glad to hear it's normal because I have just replaced my entire brake system a few months ago.
JetsterDajet
Aug 15, 2015 08:07 AM
bsmiley
Aug 13, 2015 10:32 PM
honda.lioness
Aug 6, 2015 11:58 AM
DerbyDad03
Jul 27, 2015 11:34 AM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
