Notices
Wheels and Tires Post your wheel and tire related questions here.
Front brakes griding noise
Old Jul 7, 2009
shanti.vt1's Avatar
shanti.vt1 is an unknown quantity at this point
2005 CIVIC 4 DR, Auto LXG
Hi guys here is my situation
Had my front brakes done 4 months ago. New pads and machined the old rotors.
after 4 moths my front brakes were vibrating. What I did was replaced my old rotors with new ones. Does not vibrate any more. I also did not machine the new rotors.
When I start braking and slowing down to a stop I here a bit of griding noise from my front brakes. Any idea on what it could be?
thanks
Old Jul 7, 2009
Re: Front brakes griding noise
its prolly breaking in. mine did that too and it gets less noticable over time. the pad and rotor surface need to grind in and match and also when the pad is thick, it may make some noises. could also be the rotor or pad if theyre aftermarket, alot of brands tend to be noisy compared to what honda has. i dont think you should worry.
Old Jul 7, 2009
shanti.vt1's Avatar
Thanks for the reply.....
Old Jul 7, 2009
04 Honda Civic's Avatar
You should always try to change rotors and pads together..
Old Aug 7, 2009
94honciv's Avatar
94honciv is an unknown quantity at this point
^^^^^^^ x2!!!
GolNat
Suspension DIY
May 12, 2022 06:49 AM
Misfit2613
Brakes
26
Sep 1, 2018 05:02 PM
rhvic
May 22, 2015 03:06 PM
bsmiley
Apr 27, 2015 01:27 PM
Sparty
Nov 15, 2001 04:55 PM
