Notices
Wheels and Tires Post your wheel and tire related questions here.
ABS and After Market Rims
Old Apr 15, 2008
hkhan45's Avatar
hkhan45 is an unknown quantity at this point
Hello All,
I bought a 2008 Honda Civic 1.8 i-VTEC and would like to upgrade the stock rims and tyres from 195-65-15" 91H to either 205-45-17" or 215-45-17".The width of the Rim is 8". Would the upgrade have any effect on ABS ? Kindly need some guidance on the upgrade.
Thanks in Advance.
Old Apr 15, 2008
Boilermaker1's Avatar
Jap-Euro Fusion
Re: ABS and After Market Rims
if all 4 tires are the same diameter it doesnt matter what size they are.
Old Apr 15, 2008
civicsrcool's Avatar
civicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond repute
all the rims do is roll around. so you should be okay! .
Old Apr 15, 2008
prsloco's Avatar
prsloco is an unknown quantity at this point
it really doesnt matter........abs just has to do with ur brakes....just make sure they would b able to stop the car.....the wheels shouldnt b able to get in the way.....
Old Apr 16, 2008
hkhan45's Avatar
hi,
Thanks for all the replies. But will 205-45-17 or 215-45-17 have any effect on the ABS. I have heard that larger wheels will interfere with the way ABS functions !!. Is it true ? what are the effects then ?
Waiting for a favorable reply. Thanks in advance.
Kind Regards.
Old Apr 16, 2008
civic-driver's Avatar
civic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond repute
i read through this once a while ago about the ill effects of a BBK on a ABS equipped vehicle: http://www.stoptech.com/tech_info/wp...rakekits.shtml
basing off the information given here the abs system will still work for the most part correctly because it is using wheel speed sensors to detect excessive deceleration in the wheels. i would think that have wider wheels would cause the ABS system to come into effect more often because it would more easily cause rapid deceleration. i dont think anything beyond coming on more often would happen based off of the way i understand the ABS system works as long as the wheels are the same total diameter as stock so that it wont change the wheel speed sensors readings. read through the article and decide for yourself but thats my opinion.
Old Apr 16, 2008
hkhan45's Avatar
Hi,
Thanks for the link and the info provided in the last post. I read the article but it provided info on the effects on ABS if the hardware is changed i.e rotors,calipers etc. I'm not going to change all that. I just wanted to upgrade the 15" Stock rims with 17" after market rims
Kind regards.
Old Apr 16, 2008
mugencivic08's Avatar
mugencivic08 is an unknown quantity at this point
check that site,it will tell what sizes what fits.
http://www.procivic.com/pages-honda_...ide/index.html
Old Apr 16, 2008
i know you are just upgrading the wheels the link had information about the ABS system itself... and i will say again as long as the overall diameter of the wheel is the same the ABS system should work just the same...
Old Apr 17, 2008
hkhan45's Avatar
Hi.
Thanks guys for all the replies . Really appreciated your help
Kind Regards.
Old May 3, 2008
nicokpe's Avatar
nicokpe is an unknown quantity at this point
yes thats true
Old May 3, 2008
abs WILL be affected with different size rims. how much? idk
UltraHDGames
Jun 8, 2016 05:16 PM
solarpunk70
Apr 12, 2016 11:43 AM
skeener51
Oct 1, 2015 05:56 PM
Wariogamer
Sep 29, 2015 09:49 AM
Cam Diaz
Sep 28, 2015 08:34 PM
